[OpenLayers-Users] Custom control isn't working properly - how
to unregister?
Pascal Ehlert
dadark at dadark.de
Thu Nov 22 11:24:57 EST 2007
Hi Eric!
> Your activate() and deactivate() methods should call the parent's
> methods:
> In this way, you need not yourself set active to false|true.
Cool, that stuff is working like a charm now. Thank you.
>> Sorry, but this is not working either, it complains that
>> this.map.unregister() does not return an object.
> Do you pass the appropriate parameters to unregister()?
Nope, I haven't. My fault, I was not thinking about it and just
called this.map.unregister().
I've searched the source for it's declaration and found a solution
for my problem:
this.map.events.unregister("click", this.map, this.queryHandler);
Works!!
>> That's right, but I want my users _not_ to be able to navigate
>> anymore when my own control is active.
> Sorry for misreading your former post! What you probably can do is
> unactivate() the Navigation control.
No problem, but shouldn't the Panel call the deactivate method of
Control.Navigate when changing controls?
That's at least what it does for my control ;-)
Thank you!
Pascal
