[OpenLayers-Users] VE as a base layer in Openlayers
Christopher Schmidt crschmidt at metacarta.com
Sat Nov 24 21:56:19 EST 2007
On Sun, Nov 25, 2007 at 01:47:05PM +1100, bradleyspencer wrote:
> List,
> I have been experimenting with VE as an optional base layer and have
> identified some real showstoppers that others may have a fix for.
> If you want to allow a user to interactively modify a layer’s opacity atop
> of the VE base layer, this does not work in FierFox but does in IE7. I am
> using png.
This is a bug in VE's API.
> Is this a bug that needs fixing or is VE not a serious option as a base map?
VE is not an option if you want to use client-side opacity.
Regards,
Christopher Schmidt
MetaCarta
