[OpenLayers-Users] ISO-8859-1
R. Ortner reinhard.ortner at edu.fh-kaernten.ac.at
Thu Nov 29 04:51:50 EST 2007
that will work basically. Now i can open the info in a new window and it will
diplayed correctly.
but i need to find out a way to disply it within the application. maybe not
with innerHTML but with something different. Can i use something else except
innerHTML to place it e.g. in the top right corner?
Bart van den Eijnden (OSGIS)-2 wrote:
> ResponseXML will only work if the content-type (set in the http headers)
> is
> text/xml. Then ofcourse you won't be able to set it to the innerHTML since
> it is not a string.
> I tend to believe you can only get this done using (UTF-8 and HTML) or
> (ISO8859 and XML) if you use AJAX.
> What happens if you just popup a new window with the url:
> So instead of:
> OpenLayers.loadURL(request, '', this, setHTML);
> try:
> window.open(request);
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>
> Naar: users at openlayers.org <users at openlayers.org>
> Onderwerp: Re: [OpenLayers-Users] ISO-8859-1
> Datum: 29/11/07 06:37
>> Heres my code for the getfeatureinfo part:
>> function checkinfo(imgid,url,title){
>> if (infobox == 0) {infobox = 1;}
>> if (imgid == oldimgid) {infobox = 0;}
>> id = imgid.substring(3,imgid.length);
>> 	 if(infobox == 1 &amp;&amp; document.getElementById(id).checked==true) {
>> 	 					document.getElementById('map').style.cursor = 'crosshair';
>> 						document.getElementById(imgid).src =
> &quot;img/treemenu/identify_2.gif&quot;;
>>         		if (oldimgid != null) document.getElementById(oldimgid).src =
>> &quot;img/treemenu/identify_1.gif&quot;;
>>         		oldimgid = imgid;
>>         		document.getElementById('nodeList').style.visibility =
> 'visible';
>>     map.events.register('click', map, function (e) {
>>             OpenLayers.Util.getElement('nodeList').innerHTML =
> &quot;Loading...
>> please wait...&quot;;
>>             var request =  window[id].getFullRequestString({
>>                             REQUEST: &quot;GetFeatureInfo&quot;,
>>                             EXCEPTIONS:
> &quot;application/vnd.ogc.se_xml&quot;,
>>                             BBOX: window[id].map.getExtent().toBBOX(),
>>                             X: e.xy.x,
>>                             Y: e.xy.y,
>>                             INFO_FORMAT: 'text/html',
>>                             QUERY_LAYERS: window[id].params.LAYERS,
>>                             WIDTH: window[id].map.size.w,
>>                             HEIGHT: window[id].map.size.h});
>>             OpenLayers.Event.stop(e);
>> else {
>> 	 					document.getElementById('map').style.cursor = 'auto';
>> 			 			document.getElementById('nodeList').style.visibility = 'hidden';
>> 			 			if (imgid == oldimgid) { oldimgid = null; } else { oldimgid =
> imgid;
>> 						document.getElementById('nodeList').innerHTML = &quot;&quot;;
>> 			 			infobox = 0;
>> function setHTML(response) {
> response.responseText;
>> I tried to change the response.responseText to responseXML as u told, but
>> than the Info is not displayed any more. (after mouseclick i see short
>> the
>> Loading... please wait... and than nothing!)
>> do i have then to change something about my template to, maybe with the
>> responseXML the template is not correct anymore?
>> &gt;
>> &gt; Can you explain code-wise how you perform the GetFeatureInfo
>> request?
>> &gt;
>> &gt; If the code uses responseText instead of responseXML, it can only
> work in
>> &gt; UTF-8.
>> &gt;
>> &gt; See also some threads in september titled loading XML problem, e.g.:
>> &gt;
>> &gt; http://openlayers.org/pipermail/users/2007-September/003001.html
>> &gt;
>> &gt; Best regards,
>> &gt; Bart
>> &gt;
>> &gt; --
>> &gt; Bart van den Eijnden
>> &gt; OSGIS, Open Source GIS
>> &gt; http://www.osgis.nl
>> &gt;
>> &gt;
>> &gt; --------- Oorspronkelijk bericht --------
>> &gt; Van: R. Ortner &lt;reinhard.ortner at edu.fh-kaernten.ac.at&gt;
>> &gt; Naar: users at openlayers.org &lt;users at openlayers.org&gt;
>> &gt; Onderwerp: Re: [OpenLayers-Users] ISO-8859-1
>> &gt; Datum: 29/11/07 06:00
>> &gt;
>> &gt;&gt;
>> &gt;&gt; Hi again,
>> &gt;&gt;
>> &gt;&gt; i tried to set the charset by adding &amp;lt;meta
>> &gt; http-equiv=&amp;quot;content-type&amp;quot;
>> &gt;&gt; content=&amp;quot;text/html; charset=ISO-8859-1&amp;quot;
> /&amp;gt; to the head of
>> &gt;&gt; the
>> &gt; template file
>> &gt;&gt; and by adding it to my OL index.php. I also set the apache
> defaultCharset
>> &gt; to
>> &gt;&gt; ISO-8859-1 but i still have some special characters displayed
> wrong.
>> &gt;&gt;
>> &gt;&gt; So i gess that must be something in the OpenLayers Code where
>> the
> Charset
>> &gt; is
>> &gt;&gt; set &amp;quot;wrong&amp;quot;!
>> &gt;&gt;
>> &gt;&gt; If i try to open the template file (template file for a
> getFeatrueInfo
>> &gt;&gt; request the characters displayed correctly! only wrong when OL
>> is
>> &gt; involved)
>> &gt;&gt;
>> &gt;&gt; hope some developer can tell me how to change the default
>> charset
> of OL
>> &gt;&gt;
>> &gt;&gt; thx
>> &gt;&gt;
>> &gt;&gt; ----
>> &gt;&gt;
>> &gt;&gt;
>> &gt;&gt; R. Ortner wrote:
>> &gt;&gt; &amp;gt;
>> &gt;&gt; &amp;gt; Hi,
>> &gt;&gt; &amp;gt;
>> &gt;&gt; &amp;gt; where to tell OL to show the getFeatureInfo request in
> ISO-8859-1?
>> &gt;&gt; (i
>> &gt; need
>> &gt;&gt; &amp;gt; special character support)
>> &gt;&gt; &amp;gt;
>> &gt;&gt; &amp;gt; so far i get as a result of my request for every
>> special
> character
>> &gt; like ä
>> &gt;&gt; &amp;gt; or ö -&amp;gt; � (FF) /? (in IE).
>> &gt;&gt; &amp;gt;
>> &gt;&gt; &amp;gt; regards
>> &gt;&gt; &amp;gt; R. Ortner
>> &gt;&gt; &amp;gt;
>> &gt;&gt;
>> &gt;&gt; --
>> &gt;&gt; View this message in context:
>> &gt; http://www.nabble.com/ISO-8859-1-tf4887822.html#a14021006
>> &gt;&gt; Sent from the OpenLayers Users mailing list archive at
> Nabble.com.
>> &gt;&gt;
>> &gt;&gt; _______________________________________________
>> &gt;&gt; Users mailing list
>> &gt;&gt; Users at openlayers.org
>> &gt;&gt; http://openlayers.org/mailman/listinfo/users
>> &gt;&gt;
>> &gt;
>> &gt;
>> &gt;
>> &gt;
>> &gt;
> http://www.nabble.com/ISO-8859-1-tf4887822.html#a14021264
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/ISO-8859-1-tf4887822.html#a14022546
