[OpenLayers-Users] Theme question...
Steve Lime Steve.Lime at dnr.state.mn.us
Thu Nov 29 22:44:46 EST 2007
It's the default sheet that's throwing me. It would be nice to be able to choose a
different default with the theme property. I was hoping to clone the default css and
images directory for each skin I needed (1 for public site, 1 for intranet site) and
then just change the reference when setting up the map. So in the theme directory
you'd have:
  default -> images, styles.css
  app1 -> images, styles.css
  app2 -> images, styles.css
I just thought it strange to set theme: 'theme/app1/styles.css' and see both sheets
loaded. Not sure why you'd set theme like this then. Now that I understand I can
work with it easily. Thanks again Tim.
Steve
>>> Tim Schaub <tschaub at openplans.org> 11/29/07 5:41 PM >>>
Hey-
Steve Lime wrote:
> Hi all: Question about a map's theme. My assumption is that one could use that mechanism to override the default (blue)
> styling of OpenLayers. Yet, when I do so I'm seeing (via firebug) both my theme's style.css and the default style.css being
> loaded and as a result the custom styles don't get applied. Am I misunderstanding the theme concept?
If you haven't already, see:
http://openlayers.org/dev/examples/custom-style.html
If you want to cascade styles, you have to include your stylesheets in a
link tag.  If you don't do this (or if you use anything other than
{theme: null} in your map options), you get a stylesheet added
dynamically.  This breaks cascading styles - as the default styles might
(will likely) get applied after any style declarations you have made in
your html or other linked stylesheets.
Also, note that not all style related stuff has been pulled out of the
code.  That is, there are still style declarations in the library -
these trump any you have made with css.  The skinning of OpenLayers is
definitely a work in progress.  If there is something specific that you
can't control with CSS, please make a ticket.
If you're having a different issue, disregard this.
Tim
> Steve
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> !DSPAM:4033,474f407f272433327367457!
Users mailing list
