[OpenLayers-Users] ISO-8859-1
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Fri Nov 30 05:33:15 EST 2007
That site probably does some server-side trick, since if you look in
their GetFeatureInfo responses the special characters have been
translated to htmlentities:
<p id="Text1">Gletscherkessel Pr&auml;g</p>
Best regards,
Bart
R. Ortner schreef:
> Hi,
> i´m now a little confused...
> I looked at
> http://rips-uis.lubw.baden-wuerttemberg.de/rips/wms_viewer/openlayer_test/OpenLayers.php
> cause i use the same GetFeatureInfo request  (see below). They also use
> responseText with innerHTML and they can display special characters with no
> problem.
> If I open the request in a new window everything is displayed correct but
> with the "normal" call within the application (like the lubw application)
> the special characters shown as ?.
> Any idea where else the problem could be?
> function checkinfo(imgid,url,title){
> if (infobox == 0) {infobox = 1;}
> if (imgid == oldimgid) {infobox = 0;}
> id = imgid.substring(3,imgid.length);
> 	 if(infobox == 1 && document.getElementById(id).checked==true) {
> 	 					document.getElementById('map').style.cursor = 'crosshair';
> 						document.getElementById(imgid).src = "img/treemenu/identify_2.gif";
>         		if (oldimgid != null) document.getElementById(oldimgid).src =
> "img/treemenu/identify_1.gif";
>         		oldimgid = imgid;
>         		document.getElementById('nodeList').style.visibility = 'visible';
>     map.events.register('click', map, function (e) {
>             OpenLayers.Util.getElement('nodeList').innerHTML = "Loading...
> please wait...";
>             var request =  window[id].getFullRequestString({
>                             REQUEST: "GetFeatureInfo",
>                             EXCEPTIONS: "application/vnd.ogc.se_xml",
>                             BBOX: window[id].map.getExtent().toBBOX(),
>                             X: e.xy.x,
>                             Y: e.xy.y,
>                             INFO_FORMAT: 'text/html',
>                             QUERY_LAYERS: window[id].params.LAYERS,
>                             WIDTH: window[id].map.size.w,
>                             HEIGHT: window[id].map.size.h});
>             OpenLayers.loadURL(request, '', this, setHTML);
>             OpenLayers.Event.stop(e);
> else {
> 	 					document.getElementById('map').style.cursor = 'auto';
> 			 			document.getElementById('nodeList').style.visibility = 'hidden';
> 			 			if (imgid == oldimgid) { oldimgid = null; } else { oldimgid = imgid;
> 						document.getElementById('nodeList').innerHTML = "??";
> 			 			infobox = 0;
> 						document.getElementById(imgid).src = "img/treemenu/identify_1.gif";
> function setHTML(response) {
>    OpenLayers.Util.getElement('nodeList').innerHTML = response.responseText;
> Bart van den Eijnden (OSGIS)-2 wrote:
>> You can use an iframe and set it's source (src) to the GetFeatureInfo URL.
>> Best regards,
>> Bart
>> OSGIS, Open Source GIS
>> http://www.osgis.nl
>> --------- Oorspronkelijk bericht --------
>> Van: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>
>> Naar: users at openlayers.org <users at openlayers.org>
>> Onderwerp: Re: [OpenLayers-Users] ISO-8859-1
>> Datum: 29/11/07 07:52
>>> that will work basically. Now i can open the info in a new window and it
>> will
>>> diplayed correctly.
>>> but i need to find out a way to disply it within the application. maybe
>> not
>>> with innerHTML but with something different. Can i use something else
>> except
>>> innerHTML to place it e.g. in the top right corner?
>>> &gt;
>>> &gt; ResponseXML will only work if the content-type (set in the http
>> headers)
>>> &gt; is
>>> &gt; text/xml. Then ofcourse you won't be able to set it to the innerHTML
>> since
>>> &gt; it is not a string.
>>> &gt;
>>> &gt; I tend to believe you can only get this done using (UTF-8 and HTML)
>> or
>>> &gt; (ISO8859 and XML) if you use AJAX.
>>> &gt;
>>> &gt; What happens if you just popup a new window with the url:
>>> &gt;
>>> &gt; So instead of:
>>> &gt;
>>> &gt; OpenLayers.loadURL(request, '', this, setHTML);
>>> &gt;
>>> &gt; try:
>>> &gt;
>>> &gt; window.open(request);
>>> &gt;
>>> &gt; Best regards,
>>> &gt; Bart
>>> &gt;
>>> &gt; --
>>> &gt; Bart van den Eijnden
>>> &gt; OSGIS, Open Source GIS
>>> &gt; http://www.osgis.nl
>>> &gt;
>>> &gt;
>>> &gt; --------- Oorspronkelijk bericht --------
>>> &gt; Van: R. Ortner &lt;reinhard.ortner at edu.fh-kaernten.ac.at&gt;
>>> &gt; Naar: users at openlayers.org &lt;users at openlayers.org&gt;
>>> &gt; Onderwerp: Re: [OpenLayers-Users] ISO-8859-1
>>> &gt; Datum: 29/11/07 06:37
>>> &gt;
>>> &gt;&gt;
>>> &gt;&gt; Heres my code for the getfeatureinfo part:
>>> &gt;&gt;
>>> &gt;&gt; function checkinfo(imgid,url,title){
>>> &gt;&gt;
>>> &gt;&gt; if (infobox == 0) {infobox = 1;}
>>> &gt;&gt; if (imgid == oldimgid) {infobox = 0;}
>>> &gt;&gt; id = imgid.substring(3,imgid.length);
>>> &gt;&gt; 	 if(infobox == 1 &amp;amp;&amp;amp;
>>> &gt;&gt; 	 					document.getElementById('map').style.cursor =
>>> 'crosshair';
>>> &gt;&gt; 						document.getElementById(imgid).src =
>>> &gt; &amp;quot;img/treemenu/identify_2.gif&amp;quot;;
>>> &gt;&gt;         		if (oldimgid != null)
>>> &gt;&gt; &amp;quot;img/treemenu/identify_1.gif&amp;quot;;
>>> &gt;&gt;         		oldimgid = imgid;
>>> &gt;&gt;         		document.getElementById('nodeList').style.visibility =
>>> &gt; 'visible';
>>> &gt;&gt;
>>> &gt;&gt;     map.events.register('click', map, function (e) {
>>> &gt; {
>>> 'crosshair';
>>> &gt;&gt;             OpenLayers.Util.getElement('nodeList').innerHTML =
>>> &gt; &amp;quot;Loading...
>>> &gt;&gt; please wait...&amp;quot;;
>>> &gt;&gt;             var request =  window[id].getFullRequestString({
>>> &gt;&gt;                             REQUEST:
>> &amp;quot;GetFeatureInfo&amp;quot;,
>>> &gt;&gt;                             EXCEPTIONS:
>>> &gt; &amp;quot;application/vnd.ogc.se_xml&amp;quot;,
>>> &gt;&gt;                             BBOX:
>>> &gt;&gt;                             X: e.xy.x,
>>> &gt;&gt;                             Y: e.xy.y,
>>> &gt;&gt;                             INFO_FORMAT: 'text/html',
>>> &gt;&gt;                             QUERY_LAYERS:
>>> &gt;&gt;                             WIDTH: window[id].map.size.w,
>>> &gt;&gt;                             HEIGHT: window[id].map.size.h});
>>> &gt;&gt;             OpenLayers.loadURL(request, '', this, setHTML);
>>> &gt;&gt;             OpenLayers.Event.stop(e);
>>> &gt;&gt; 				}
>>> &gt;&gt;       });
>>> &gt;&gt; 		}
>>> &gt;&gt; else {
>>> &gt;&gt; 	 					document.getElementById('map').style.cursor = 'auto';
>> 'hidden';
>>> &gt;&gt; 			 			if (imgid == oldimgid) { oldimgid = null; } else {
>> oldimgid =
>>> &gt; imgid;
>>> &gt;&gt; }
>>> &gt;&gt; 						document.getElementById('nodeList').innerHTML =
>> &amp;quot;&amp;quot;;
>>> &gt;&gt; 			 			infobox = 0;
>>> &gt;&gt; 						}
>>> &gt;&gt; }
>>> &gt;&gt;
>>> &gt;&gt; function setHTML(response) {
>>> &gt; response.responseText;
>>> &gt;&gt; }
>>> &gt;&gt;
>>> &gt;&gt;
>>> &gt;&gt; I tried to change the response.responseText to responseXML as u
>> told, but
>>> &gt;&gt; than the Info is not displayed any more. (after mouseclick i see
>> short
>>> &gt;&gt; the
>>> &gt;&gt; Loading... please wait... and than nothing!)
>>> &gt;&gt; do i have then to change something about my template to, maybe
>> with the
>>> &gt;&gt; responseXML the template is not correct anymore?
>>> &gt;&gt;
>>> &gt;&gt;
>>> &gt;&gt; ----
>>> &gt;&gt;
>>> &gt;&gt;
>>> &gt;&gt;
>>> &gt;&gt; Bart van den Eijnden (OSGIS)-2 wrote:
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt; Can you explain code-wise how you perform the
>> GetFeatureInfo
>>> &gt;&gt; request?
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt; If the code uses responseText instead of responseXML,
>>> it
>> can only
>>> &gt; work in
>>> &gt;&gt; &amp;gt; UTF-8.
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt; See also some threads in september titled loading XML
>> problem, e.g.:
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt;
>> http://openlayers.org/pipermail/users/2007-September/003001.html
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt; Best regards,
>>> &gt;&gt; &amp;gt; Bart
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt; --
>>> &gt;&gt; &amp;gt; Bart van den Eijnden
>>> &gt;&gt; &amp;gt; OSGIS, Open Source GIS
>>> &gt;&gt; &amp;gt; http://www.osgis.nl
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt; --------- Oorspronkelijk bericht --------
>>> &gt;&gt; &amp;gt; Van: R. Ortner
>> &amp;lt;reinhard.ortner at edu.fh-kaernten.ac.at&amp;gt;
>>> &gt;&gt; &amp;gt; Naar: users at openlayers.org
>> &amp;lt;users at openlayers.org&amp;gt;
>>> &gt;&gt; &amp;gt; Onderwerp: Re: [OpenLayers-Users] ISO-8859-1
>>> &gt;&gt; &amp;gt; Datum: 29/11/07 06:00
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt;&amp;gt;
>>> &gt;&gt; &amp;gt;&amp;gt; Hi again,
>>> &gt;&gt; &amp;gt;&amp;gt; i tried to set the charset by adding
>> &amp;amp;lt;meta
>>> &gt;&gt; &amp;gt; http-equiv=&amp;amp;quot;content-type&amp;amp;quot;
>>> &gt;&gt; &amp;gt;&amp;gt; content=&amp;amp;quot;text/html;
>> charset=ISO-8859-1&amp;amp;quot;
>>> &gt; /&amp;amp;gt; to the head of
>>> &gt;&gt; &amp;gt;&amp;gt; the
>>> &gt;&gt; &amp;gt; template file
>>> &gt;&gt; &amp;gt;&amp;gt; and by adding it to my OL index.php. I also set
>> the apache
>>> &gt; defaultCharset
>>> &gt;&gt; &amp;gt; to
>>> &gt;&gt; &amp;gt;&amp;gt; ISO-8859-1 but i still have some special
>> characters displayed
>>> &gt; wrong.
>>> &gt;&gt; &amp;gt;&amp;gt; So i gess that must be something in the
>> OpenLayers Code where
>>> &gt;&gt; the
>>> &gt; Charset
>>> &gt;&gt; &amp;gt; is
>>> &gt;&gt; &amp;gt;&amp;gt; set &amp;amp;quot;wrong&amp;amp;quot;!
>>> &gt;&gt; &amp;gt;&amp;gt; If i try to open the template file (template
>> file for a
>>> &gt; getFeatrueInfo
>>> &gt;&gt; &amp;gt;&amp;gt; request the characters displayed correctly!
>>> only
>> wrong when OL
>>> &gt;&gt; is
>>> &gt;&gt; &amp;gt; involved)
>>> &gt;&gt; &amp;gt;&amp;gt; hope some developer can tell me how to change
>> the default
>>> &gt;&gt; charset
>>> &gt; of OL
>>> &gt;&gt; &amp;gt;&amp;gt; thx
>>> &gt;&gt; &amp;gt;&amp;gt; ----
>>> &gt;&gt; &amp;gt;&amp;gt; R. Ortner wrote:
>>> &gt;&gt; &amp;gt;&amp;gt; &amp;amp;gt;
>>> &gt;&gt; &amp;gt;&amp;gt; &amp;amp;gt; Hi,
>>> &gt;&gt; &amp;gt;&amp;gt; &amp;amp;gt; where to tell OL to show the
>> getFeatureInfo request in
>>> &gt; ISO-8859-1?
>>> &gt;&gt; &amp;gt;&amp;gt; (i
>>> &gt;&gt; &amp;gt; need
>>> &gt;&gt; &amp;gt;&amp;gt; &amp;amp;gt; special character support)
>>> &gt;&gt; &amp;gt;&amp;gt; &amp;amp;gt; so far i get as a result of my
>> request for every
>>> &gt;&gt; special
>>> &gt; character
>>> &gt;&gt; &amp;gt; like ä
>>> &gt;&gt; &amp;gt;&amp;gt; &amp;amp;gt; or ö -&amp;amp;gt; � (FF) /? (in
>> IE).
>>> &gt;&gt; &amp;gt;&amp;gt; &amp;amp;gt; regards
>>> &gt;&gt; &amp;gt;&amp;gt; &amp;amp;gt; R. Ortner
>>> &gt;&gt; &amp;gt;&amp;gt; View this message in context:
>>> &gt;&gt; &amp;gt;
>> http://www.nabble.com/ISO-8859-1-tf4887822.html#a14021006
>>> &gt;&gt; &amp;gt;&amp;gt; Sent from the OpenLayers Users mailing list
>> archive at
>>> &gt; Nabble.com.
>>> &gt;&gt; &amp;gt;&amp;gt; _______________________________________________
>>> &gt;&gt; &amp;gt;&amp;gt; Users mailing list
>>> &gt;&gt; &amp;gt;&amp;gt; Users at openlayers.org
>>> &gt;&gt; &amp;gt;&amp;gt; http://openlayers.org/mailman/listinfo/users
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt; _______________________________________________
>>> &gt;&gt; &amp;gt; Users mailing list
>>> &gt;&gt; &amp;gt; Users at openlayers.org
>>> &gt;&gt; &amp;gt; http://openlayers.org/mailman/listinfo/users
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt; &amp;gt;
>>> &gt;&gt;
>>> &gt;&gt; --
>>> &gt;&gt; View this message in context:
>>> &gt; http://www.nabble.com/ISO-8859-1-tf4887822.html#a14021264
>>> &gt;&gt; Sent from the OpenLayers Users mailing list archive at
>> Nabble.com.
>>> &gt;&gt;
>>> &gt;&gt; _______________________________________________
>>> &gt;&gt; Users mailing list
>>> &gt;&gt; Users at openlayers.org
>>> &gt;&gt; http://openlayers.org/mailman/listinfo/users
>>> &gt;&gt;
>>> &gt;
>>> &gt;
>>> &gt;
>>> &gt;
>>> &gt;
>> http://www.nabble.com/ISO-8859-1-tf4887822.html#a14022546
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>> Users mailing list
bartvde at osgis.nl
http://www.osgis.nl
