[OpenLayers-Users] Rounding BBOX?
Per-Olof Norén
pelle at alma.nu
Tue Oct 2 09:23:09 EDT 2007
Hi list,
I'm currently part of a project that uses ArcIMS WMSConnector as WMS
serving a raster base layer to an OpenLayers client. All this is done in
the projection "RT90 Swedish grid", EPSG:2400. No problems.
OpenLayers is set up with specific scales according to this:
OpenLayers.IMAGE_RELOAD_ATTEMPTS = 2;
var rt90bbox = new OpenLayers.Bounds(1200000, 6100000, 1900000, 7700000);
var options = {
maxExtent: rt90bbox,
scales: [
8000000,4000000,2000000, 1000000,500000,250000, 150000,100000,75000,
50000,25000,20000,15000,12500,10000,5000,2500],
units: 'm',
projection: "EPSG:2400",
controls: [new OpenLayers.Control.MouseDefaults()]
var map = new OpenLayers.Map("map", options);
var baseLayer1 = new OpenLayers.Layer.WMS("Baselayer",
urls,
{layers: 'sverige' , format:'image/png'},
{isBaseLayer: true, projection: 'EPSG:2400'});
Now, at certain zoom-levels the WMSConnector is apparently doing some
illegal math and requested tile is generated with a white stripe along
one or two sides. Same behaviour is seen when the image src that
Openlayers generates is called directly, so its not that OpenLayers is
doing something wrong. Its ArcIMS.
The problem seems to go away, at large zoom levels (1:2500) if one
removes the decimals from the BBOX generated by OpenLayers.
I found this
http://www.nabble.com/Rounding-BBOX-t2383934.html
Is there a way of setting a global or layer specific rounding of BBOX in
Open Layers 2.4 ?
ps
I'm not in position to either debug or file an ESRI support issue
regarding this. I'm merely looking for a client-side workaround.
ds
regards,
Per-Olof
