[OpenLayers-Users] Proportional Symbol Mapping
Eric Lemoine
eric.c2c at gmail.com
Sun Apr 6 15:44:18 EDT 2008
On Sun, Apr 6, 2008 at 7:24 PM, Andreas Hocevar
<andreas.hocevar at gmail.com> wrote:
> Bjorn,
> your requirement is covered by the new OpenLayers.StyleMap.
> First of all, have a look at the styles-context example
> (http://www.openlayers.org/dev/examples/styles-context.html). The second
> example there (the points in the southern hemisphere) are created with
> an advanced template. The same can be done for your use case.
> If I take your original code for the calculation of the size:
> feature.style.pointRadius = 3 + (pop * (40 / 1312978855));
> feature.style.fillColor = feature.attributes['colour'];
> I can create the following template:
> var context = {
> getSize: function(feature) {
> return feature.attributes["population"] * someFactor * map.getScale();
> getColour: function(feature) {
> return feature.attributes["colour"];
> var template = {
> fillOpacity: 0.9
> pointRadius: "${getSize}", // using context.getSize(feature)
> fillColor: "${getColour}" // using context.getColour(feature)
> var style = new OpenLayers.Style(template, {context: context});
> vectors = new OpenLayers.Layer.Vector("Vector Layer", {
> styleMap: new OpenLayers.StyleMap(style)});
> You only have to find an algorithm to derive your pointRadius from
> (using map.getScale() or map.getResolution() and someFactor).
> Also, there is no need to set any feature styles in the onload method.
> You're all set with the above definition of the styleMap in the
> constructor for your vector layer.
Thanks for this detailed explanation Andreas. The style/rule framework
is so rich that it's kinda hard to keep up with all of its features.
Eric
