[OpenLayers-Users] Proportional Symbol Mapping
Bjorn Sandvik
B.Sandvik at sms.ed.ac.uk
Sun Apr 6 19:01:02 EDT 2008
Thank you!
The circles are now scaling properly on each zoom level:
http://thematicmapping.org/experiments/openlayers/propsymbols_stylemap.html
How can I adjust the hover effect (keep the same size)?
Bjorn
Andreas Hocevar wrote:
> Bjorn,
> your requirement is covered by the new OpenLayers.StyleMap.
> First of all, have a look at the styles-context example
> (http://www.openlayers.org/dev/examples/styles-context.html). The
> second example there (the points in the southern hemisphere) are
> created with an advanced template. The same can be done for your use
> case.
> If I take your original code for the calculation of the size:
> feature.style.pointRadius = 3 + (pop * (40 / 1312978855));
> feature.style.fillColor = feature.attributes['colour'];
> I can create the following template:
> var context = {
> getSize: function(feature) {
> return feature.attributes["population"] * someFactor *
> map.getScale();
> getColour: function(feature) {
> return feature.attributes["colour"];
> var template = {
> fillOpacity: 0.9
> pointRadius: "${getSize}", // using context.getSize(feature)
> fillColor: "${getColour}" // using context.getColour(feature)
> var style = new OpenLayers.Style(template, {context: context});
> vectors = new OpenLayers.Layer.Vector("Vector Layer", {
> styleMap: new OpenLayers.StyleMap(style)});
> You only have to find an algorithm to derive your pointRadius from
> (using map.getScale() or map.getResolution() and someFactor).
> Also, there is no need to set any feature styles in the onload method.
> You're all set with the above definition of the styleMap in the
> constructor for your vector layer.
> Regards,
> Andreas.
> Bjorn Sandvik wrote:
>> My question: Is there a way to keep the relative size of the symbols
>> when the users zoom in/out?
>> (symbols should keep their size relative to the size of the countries).
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
