[OpenLayers-Users] WKT reprojection
Cranio cranio at quipo.it
Mon Apr 21 09:28:31 EDT 2008
Hi folks,
I am writing a web application using MySQL/OpenLayers/AJAX/PHP; this app
must enable some users to draw a vector shape and then import it in a
Spatial-aware MySQL database.
Now, everything is theoretically fine, till I have to put the actual
polygonal data in the database; 'cause I use for this the WKT format
exported string, but the resulting string is calculated on the Google base
layer projection (EPSG:900913).
That won't do, because my database holds data in UTM33S projection
(EPSG:32733), and I want data to be consistent among already existing
pre-defined shapes.
Is there a way to force the point coordinates to show up in the other EPSG
projection, so I can put them directly in the DB with a single and
straightforward query (obviously without performing boring string parsing
and coord conversion routines)?
View this message in context: http://www.nabble.com/WKT-reprojection-tp16807918p16807918.html
