[OpenLayers-Users] Problems with drawing a regular polygon in a non-4326 layer
Eric Lemoine eric.c2c at gmail.com
Tue Aug 12 03:49:42 EDT 2008
On Mon, Aug 11, 2008 at 9:34 PM, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
> Hi
> I have problems with drawing a regular polygon in a layer with a different
> EPSG-code than 4326. It shows up perfectly after the mouse-up event but is
> not shown while the mouse-down event. The vector layer is defined as
> follows:
> var polygonLayer = new OpenLayers.Layer.Vector("DXF",
> maxExtent: new OpenLayers.Bounds(590000,213500,645000,262000),
> maxResolution: 'auto',
> projection:"EPSG:21781",
> units:"m"
> Without the options the vector layer is disabled at a certain scale but the
> polygon is shown while the mouse button is down. Any ideas? (The example can
> be found here: http://www.john-longo.org/geo/geobau.html)
I think this is fixed in trunk. Try using
<http://dev.openlayers.org/nightly/OpenLayers.js> instead of
<http://www.openlayers.org/api/OpenLayers.js> as your <script src=">.
Thanks,
Eric
