[OpenLayers-Users] free base maps
Bilge Tutak bilge.tutak at gmail.com
Tue Aug 12 23:34:15 EDT 2008
Thanks everybody,
Is there any code examples or actual URL I can use for these maps? I also found
openstreetmaps. Is this also a free option? It does not have
satellite, but has pretty nice topo maps.
Bilge.
On Tue, Aug 12, 2008 at 7:06 PM, Nathan Gerber <ngerber999 at gmail.com> wrote:
> True enough, I forgot all about that as I had actually made a local cache of
> it for that exact reason.
> Nathan Gerber
> On Tue, Aug 12, 2008 at 5:20 PM, Anselm Hook <anselm at gmail.com> wrote:
>> and onearth falls over pretty much all the time; it is remarkably
>> unstable.
>> - me
>> On Tue, Aug 12, 2008 at 1:15 PM, Nathan Gerber <ngerber999 at gmail.com>
>> wrote:
>>> http://onearth.jpl.nasa.gov/ has global coverage (minus the poles) and is
>>> decent for regional views but is limited to 15 meter per pixel as its best
>>> resolution with 30m being the best in some regions. So if you need close up
>>> views it won't fit your needs.
>>> Sorry Gregor, I meant to do a reply-all on the original post.
>>> Nathan Gerber
>>> On Tue, Aug 12, 2008 at 3:45 PM, Bilge Tutak <bilge.tutak at gmail.com>
>>> wrote:
>>>> Hi All,
>>>> I am currently using Openlayers with the base map from Openlayers.
>>>> I am curious if there are other free map services that can give base
>>>> maps like the Openlayers maybe also with satellite imagery?
>>>> I already know Google, Yahoo and MS ones. From these Google is the
>>>> most useful for me in terms of maps, but
>>>> I can not use it because my application is not running on single
>>>> domain (actually does not run on an actual domain, except like
>>>> localhost).
>>>> Thanks,
>>>> Bilge.
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
