[OpenLayers-Users] Styling a feature with multiple attributes
using SLD - solved
Zer
hcan at hotmail.com
Wed Aug 27 12:30:09 EDT 2008
I just found the problem! I hade forgotten to add a rule for when the
isMarked is not true! This is what was missing:
<sld:Rule>
<sld:Name>Is_Marked and Code</sld:Name>
<ogc:Filter>
<ogc:And>
<ogc:Not>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>isMarked</ogc:PropertyName>
<ogc:Literal>1</ogc:Literal>
</ogc:PropertyIsEqualTo>
<ogc:Not>
<ogc:PropertyName>code</ogc:PropertyName>
<ogc:Literal>2</ogc:Literal>
</ogc:And>
</ogc:Filter>
<sld:PolygonSymbolizer>
<sld:Fill>
<sld:CssParameter name="fill">
<ogc:Literal>#00FFFF</ogc:Literal>
</sld:CssParameter>
<sld:CssParameter name="stroke">
<ogc:Literal>white</ogc:Literal>
</sld:CssParameter>
</sld:Fill>
</sld:PolygonSymbolizer>
</sld:Rule>
Zer wrote:
> Hi all,
> I have a vector layer with features with attributes. I would like to use
> two of these attributes to style the features. One attribute is a code
> that have values between 1-10. The other attribute is a boolean
> (isMarked). I would like to change the fill property (gradient colours) of
> the attribute depending on the code and add a red stroke to the attribute
> if the isMarked == 1. The users select which option to theme by selection
> two check boxes. I have been successful doing this with an SLD.XML file
> and it works fine if i select one of these options at a time. However,
> when i try to combine these attributes i can not get it to work. I would
> like to both add the gradient colours AND the red stroke option if
> isMarked == 1, otherwise only the fill gradient colours . Does anyone know
> how to write such a filter? Or is there another way to make this happen?
> This is the rules i have uses so far:
> ** This works if I select the code check box only **
> <sld:Rule>
> <sld:Name>Code</sld:Name>
> <ogc:Filter>
> </ogc:Filter>
> <sld:Fill>
> </sld:CssParameter>
> </sld:CssParameter>
> </sld:Fill>
> </sld:Rule>
> ** This works if I select the isMarked check box only **
> <sld:Rule>
> <sld:Name>Code and Is_Marked</sld:Name>
> <ogc:Filter>
> </ogc:Filter>
> <sld:Fill>
> </sld:CssParameter>
> <ogc:Literal>red</ogc:Literal>
> </sld:CssParameter>
> </sld:Fill>
> </sld:Rule>
> ** This does not work if I select BOTHE check boxes. **
> <sld:Rule>
> <ogc:Filter>
> <ogc:And>
> </ogc:And>
> </ogc:Filter>
> <sld:Fill>
> </sld:CssParameter>
> </sld:CssParameter>
> </sld:Fill>
> </sld:Rule>
View this message in context: http://www.nabble.com/Styling-a-feature-with-multiple-attributes-using-SLD-tp19165654p19184694.html
