[OpenLayers-Users] GeoJSON layer and modifyFeature control
Adorian Ardelean
mynature at gmail.com
Thu Dec 4 13:53:06 EST 2008
Hi Eric,
No...it is not working yet. There is some improvement indeed: I can see now
the selection style, but vertexes are still not editable.
I have tried to adapt the suggestion in post I have mentioned earlier.
var styleMap = new OpenLayers.StyleMap();
var rules = [new OpenLayers.Rule({
symbolizer: template,
elseFilter: true
styleMap.styles["default"].addRules(rules);
Using this the edit polygon works!!!. However, I did not figured out how to
include "context" within this. Select style is also not visible (but I do
not mind this, I can most probably find a work around for selection style).
Initially I have used:
var mystyle = new OpenLayers.Style(template, {context: context});
var styleMap = new OpenLayers.StyleMap(mystyle);
And context worked fine.
Any hints on how to include context with rules?
Thank you,
Adorian
On Thu, Dec 4, 2008 at 5:58 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> Hello
> Try:
> new OpenLayers.StyleMap({
> "default": yourStyle
> Hope this helps,
> Eric
> 2008/12/4, Adorian Ardelean <mynature at gmail.com>:
> > Hi again,
> > I have eliminated also the context for style as a source of problem for
> the
> > modifyFeature control not working. So it seems that just by specifying a
> > styleMap as option when declaring the vector layer makes the
> modifyFeature
> > control not functional.
> > var template = {
> > fillOpacity: 0.6,
> > fillColor: "red",
> > strokeColor:"orange",
> > strokeWidth:"1"
> > var mystyle = new OpenLayers.Style(template);
> > var regions = new
> OpenLayers.Layer.Vector("regions",{extractAttributes:true,
> > format: OpenLayers.Format.GeoJSON, projection: new
> > OpenLayers.Projection("EPSG:4326"), styleMap: new
> > OpenLayers.StyleMap(mystyle)});
> > I think the solution might be somewhere in the post:
> > StyleMap and ModifyFeatures aren't compatible ?I will give it a try.
> > All the best,
> > Adorian
> > Dr. Adorian Ardelean
> > coordinator of myNature Project
> > http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
> > biodiversity-database]
> > http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
proiectul myNature
str. Rascoala din 1907 nr 12
Timisoara 300523
Romania
Projects in which I was involved:
http://hercules.kgs.ku.edu/Hexacoral/Anemone2/ [Hexacorallians of the World]
http://www.ubio.org [uBio Project]
http://portal.ubio.org [uBio Portal]
http://microscope.mbl.edu [micro*scope Project]
http://starcentral.mbl.edu/biopedia [BioPedia]
http://starcentral.mbl.edu/custar [CU*STAR]
http://planktonnet.awi.de/index.php [planktonNet]
Yahoo messenger: transylvaniasan
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081204/c9e9279b/attachment.html
