[OpenLayers-Users] GeoJSON layer and modifyFeature control
Adorian Ardelean
mynature at gmail.com
Fri Dec 5 04:28:02 EST 2008
Hi Eric,
I've already passed through something like this. At least the code looks
similar to me. Code is below:
var mycontext = {
getColor: function(feature)
var jsonvalue = feature.attributes["fillcolor"];
return jsonvalue;
var contexttemplate = {
fillOpacity: 0.6,
fillColor: "${getColor}",
strokeColor:"orange",
strokeWidth:"1"
var contextStyle = new OpenLayers.Style(contexttemplate,mycontext);
var myStyleMap = new OpenLayers.StyleMap({"default":contextStyle});
var rules = [new OpenLayers.Rule({
symbolizer: contexttemplate,
context: mycontext,
elseFilter: true
myStyleMap.styles["default"].addRules(rules);
myStyleMap.styles["select"].addRules(rules); (w/ or w/o this line does not
work)
var regions = new OpenLayers.Layer.Vector("regions",{extractAttributes:true,
format: OpenLayers.Format.GeoJSON, projection: new
OpenLayers.Projection("EPSG:4326"), styleMap: myStyleMap});
The fill color is not changed accordingly to color I have in GeoJSON file
under attribute fillcolor. All other properties in template are applied. The
edit function does not work.
If I remove {"default":contextStyle} from OpenLayers.StyleMap(
{"default":contextStyle}); and we remain only with
var myStyleMap = new OpenLayers.StyleMap(); and all rest of code the same,
the edit function works. But still no fillcolor context is applied.
I have also oversimplified the code in a separate page, but result is
identical.
All the best,
Adorian
> I added the code below to the modify-feature.html example and it
> worked for me (code is based on Alexandre's):
> var tpl = {
> pointRadius: "${radius}",
> fillOpacity: 0.4,
> strokeColor: "#000000",
> strokeWidth: 2
> var ctx = {
> context: {
> radius: function(feature) {
> return 10;
> var oStyle = new OpenLayers.Style(tpl, ctx);
> var oStyleMap = new OpenLayers.StyleMap({
> "default": oStyle,
> // works w/ or w/o the following
> "select": new OpenLayers.Style({
> fillColor: "#66ccff",
> fillOpacity: 0.2,
> strokeColor: "#3399ff"
> var aoTypeColor = {
> '1': {fillColor:"blue"},
> '2': {fillColor:"red"},
> '3': {fillColor:"yellow"},
> '4': {fillColor:"white"}
> oStyleMap.addUniqueValueRules("default", "Type", aoTypeColor);
> oStyleMap.addUniqueValueRules("select", "Type", aoTypeColor);
> var rules = [
> symbolizer: tpl,
> context: ctx,
> elseFilter: true
> oStyleMap.styles["default"].addRules(rules);
> oStyleMap.styles["select"].addRules(rules);
> Eric
Dr. Adorian Ardelean
coordinator of myNature Project
http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
biodiversity-database]
http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081205/e9b7a0ef/attachment.html
