[OpenLayers-Users] DrawFeature with callback?
Nino Saturnino Martinez Vazquez Wael
nino.martinez at jayway.dk
Fri Dec 5 08:03:19 EST 2008
Okay so I now have this, still not working though:
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>OpenLayers Regular Polygon Example</title>
<script src="http://openlayers.org/api/OpenLayers.js"></script>
<script type="text/javascript">
var map, polygonControl;
OpenLayers.Util.onImageLoadErrorColor = "transparent";
function init(){
map = new OpenLayers.Map('map');
var wmsLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://labs.metacarta.com/wms/vmap0?", {layers: 'basic'});
var polygonLayer = new OpenLayers.Layer.Vector("Polygon Layer");
map.addLayers([wmsLayer, polygonLayer]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.addControl(new OpenLayers.Control.MousePosition());
dosomething = function (polygon)
//do something with polygon
alert("yeeehaaa");
polyOptions = {sides: 4, callbacks: {'featureAdded':
dosomething} };
polygonControl = new
OpenLayers.Control.DrawFeature(polygonLayer,
OpenLayers.Handler.RegularPolygon,
{handlerOptions: polyOptions
map.addControl(polygonControl);
map.setCenter(new OpenLayers.LonLat(0, 0), 3);
document.getElementById('noneToggle').checked = true;
function setOptions(options) {
polygonControl.handler.setOptions(options);
function setSize(fraction) {
var radius = fraction * map.getExtent().getHeight();
polygonControl.handler.setOptions({radius: radius,
angle: 0});
</script>
</head>
<body onload="init()">
<h2 id="title">OpenLayers Regular Polygon Example</h2>
<p id="shortdesc">
Shows how to use the RegularPolygon handler to draw features with
different numbers of sides.
</p>
<div id="map" class="smallmap"></div>
<div id="config">
<ul id="controls"><b>Map Controls</b>
<li>
<input type="radio" name="type"
value="none" id="noneToggle"
onclick="polygonControl.deactivate()"
checked="checked" />
<label for="noneToggle">navigate</label>
</li>
<li>
value="polygon" id="polygonToggle"
onclick="polygonControl.activate()" />
<label for="polygonToggle">draw polygon</label>
</li>
</ul>
</div>
</body>
</html>
Adorian Ardelean wrote:
> Hi,
> I presume you have to specify the event name somehow. Try including this:
> dosomething = function (feature)
> ...callbacks: {'featureAdded': dosomething}...
> All the best,
> Adorian
> On Fri, Dec 5, 2008 at 12:59 PM, Nino Saturnino Martinez Vazquez Wael
> <nino.martinez at jayway.dk <mailto:nino.martinez at jayway.dk>> wrote:
> Hi Guys
> Im doing a integration for the Apache Wicket framework(
> http://wicketstuff.org/confluence/display/STUFFWIKI/wicket-contrib-openlayers
> ), and want to add some more features. Im looking into adding the
> possibility to draw polygons, however I cant find a example where
> theres
> a simple callback involved once the polygon are drawn, however the api
> mentions it's possible.
> As you can see from the below code the only thing I need for this
> little
> thing to work are the function that calls the alert to be picked up.
> Please say if you want me to elaborate further.
> <head>
> function init(){
> 'basic'});
> Layer");
> {function(value){alert('yeeeha');}} };
> {handlerOptions:
> polyOptions
> document.getElementById('irregularToggle').checked =
> false;
> angle: 0});
> </script>
> </head>
> <p id="shortdesc">
> </p>
> <div id="config">
> <li>
> </li>
> <li>
> </li>
> </ul>
> </div>
> </body>
> </html>
> -Nino
> Users mailing list
> Users at openlayers.org <mailto:Users at openlayers.org>
> http://openlayers.org/mailman/listinfo/users
> Dr. Adorian Ardelean
> coordinator of myNature Project
> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
> biodiversity-database]
> http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
-Wicket for love
Nino Martinez Wael
Java Specialist @ Jayway DK
http://www.jayway.dk
+45 2936 7684
