[OpenLayers-Users] DrawFeature with callback?
Nino Saturnino Martinez Vazquez Wael nino.martinez at jayway.dk
Mon Dec 8 05:19:55 EST 2008
The stuff that Adorian wrote about worked :)
But thanks Arnd..
Arnd Wippermann wrote:
> There seems to be only "cancel" and "done" as callbacks for
> OpenLayers.Handler.RegularPolygon, but how to use them I don't have a clue.
> The "done" callback is declared in OpenLayers.Control.DrawFeature to draw
> the feature, trigger "featureadded" and call a empty function featureAdded.
> This function you can declare to do something after the feature is added to
> the layer.
> polygonControl.featureAdded = function() { dosomething();};
> or (not tested) you can register the event "featureadded" to the control.
> Arnd Wippermann
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Nino Saturnino Martinez Vazquez Wael
> Gesendet: Freitag, 5. Dezember 2008 14:03
> An: Adorian Ardelean
> Cc: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] DrawFeature with callback?
> Okay so I now have this, still not working though:
> <html xmlns="http://www.w3.org/1999/xhtml">
>   <head>
>     <title>OpenLayers Regular Polygon Example</title>
>     <script src="http://openlayers.org/api/OpenLayers.js"></script>
>     <script type="text/javascript">
>         var map, polygonControl;
>         OpenLayers.Util.onImageLoadErrorColor = "transparent";
>         function init(){
>             map = new OpenLayers.Map('map');
>             var wmsLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>                 "http://labs.metacarta.com/wms/vmap0?", {layers: 'basic'});
>             var polygonLayer = new OpenLayers.Layer.Vector("Polygon Layer");
>             map.addLayers([wmsLayer, polygonLayer]);
>             map.addControl(new OpenLayers.Control.LayerSwitcher());
>             map.addControl(new OpenLayers.Control.MousePosition());
>             dosomething = function (polygon)
>                 //do something with polygon
>                 alert("yeeehaaa");
>             polyOptions = {sides: 4, callbacks: {'featureAdded':
> dosomething}  };
>             polygonControl = new
> OpenLayers.Control.DrawFeature(polygonLayer,
>                                             {handlerOptions: polyOptions
>             map.addControl(polygonControl);
>             map.setCenter(new OpenLayers.LonLat(0, 0), 3);
>             document.getElementById('noneToggle').checked = true;
>         function setOptions(options) {
>             polygonControl.handler.setOptions(options);
>         function setSize(fraction) {
>             var radius = fraction * map.getExtent().getHeight();
>             polygonControl.handler.setOptions({radius: radius,
>                                                angle: 0});
>     </script>
>   </head>
>   <body onload="init()">
>     <h2 id="title">OpenLayers Regular Polygon Example</h2>
>     <p id="shortdesc">
>       Shows how to use the RegularPolygon handler to draw features with
>       different numbers of sides.
>     </p>
>     <div id="map" class="smallmap"></div>
>     <div id="config">
>         <ul id="controls"><b>Map Controls</b>
>             <li>
>                 <input type="radio" name="type"
>                        value="none" id="noneToggle"
>                        onclick="polygonControl.deactivate()"
>                        checked="checked" />
>                 <label for="noneToggle">navigate</label>
>             </li>
>             <li>
>                        value="polygon" id="polygonToggle"
>                        onclick="polygonControl.activate()" />
>                 <label for="polygonToggle">draw polygon</label>
>             </li>
>         </ul>
>     </div>
>   </body>
> </html>
> Adorian Ardelean wrote:
>> Hi,
>> I presume you have to specify the event name somehow. Try including this:
>> dosomething = function (feature)
>>  ...callbacks: {'featureAdded': dosomething}...
>> All the best,
>> Adorian
>> On Fri, Dec 5, 2008 at 12:59 PM, Nino Saturnino Martinez Vazquez Wael
>> <nino.martinez at jayway.dk <mailto:nino.martinez at jayway.dk>> wrote:
>>     Hi Guys
>>     Im doing a integration for the Apache Wicket framework(
> http://wicketstuff.org/confluence/display/STUFFWIKI/wicket-contrib-openlayer
> s
>>     ), and want to add some more features. Im looking into adding the
>>     possibility to draw polygons, however I cant find a example where
>>     theres
>>     a simple callback involved once the polygon are drawn, however the api
>>     mentions it's possible.
>>     As you can see from the below code the only thing I need for this
>>     little
>>     thing to work are the function that calls the alert to be picked up.
>>     Please say if you want me to elaborate further.
>>      <head>
>>            function init(){
>>     'basic'});
>>     Layer");
>>     {function(value){alert('yeeeha');}}  };
>>                                                {handlerOptions:
>>     polyOptions
>>                 document.getElementById('irregularToggle').checked =
>>     false;
>>                                                   angle: 0});
>>        </script>
>>      </head>
>>        <p id="shortdesc">
>>        </p>
>>        <div id="config">
>>                <li>
>>                </li>
>>                <li>
>>                </li>
>>            </ul>
>>        </div>
>>      </body>
>>     </html>
>>     -Nino
>>     _______________________________________________
>>     Users mailing list
>>     Users at openlayers.org <mailto:Users at openlayers.org>
>>     http://openlayers.org/mailman/listinfo/users
>> Dr. Adorian Ardelean
>> coordinator of myNature Project
>> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
>> biodiversity-database]
>> http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
> -Wicket for love
> Nino Martinez Wael
> Java Specialist @ Jayway DK
> http://www.jayway.dk
> +45 2936 7684
> Users mailing list
-Wicket for love
Nino Martinez Wael
+45 2936 7684
