[OpenLayers-Users] Getting all points for a geom?
Guillermo Lopez Mackinnon
gmlopez.mackinnon at gmail.com
Mon Dec 8 09:28:41 EST 2008
Ok. Many thanks again!
As I said I'll try it out and provide feedback :-)
Best regards,
Guillermo
On Mon, Dec 8, 2008 at 3:18 PM, Adorian Ardelean <mynature at gmail.com> wrote:
> Hi Guillermo,
> I have not tried it with a WFS layer, but I think it should work (I infer
> by looking at other examples on this list).
> You may add the control when you initialize the rest of other controls you
> use. The "..." stands for other controls :-)
> I think you have to create the layer before you create the controls for it.
> Just follow regular init() code as in other OL examples. Then when you want
> to get a feature info you may use some code to activate the featureinfocontrol
> (by click on a form entity, or image etc. associated with a "toggle"
> function).
> All the best,
> Adorian
> On Mon, Dec 8, 2008 at 2:53 PM, Guillermo Lopez Mackinnon <
> gmlopez.mackinnon at gmail.com> wrote:
>> Hey! Many thanks!
>> That sounds like a great hint and like the correct approach too :-)!
>> What should I do with the controls variable? Add it to the layer at
>> creation time?
>> For example:
>> controls = {
>> featureinfocontrol: new OpenLayers.Control.SelectFeature(myvectorlayer,
>> {onSelect: featureinfo});
>> var cities = new OpenLayers.Layer.WFS(
>> "Cities",
>> "http://localhost:8080/geoserver/wfs",
>> {typename: 'topp:cities'},
>> typename: 'cities',
>> featureNS: 'http://www.openplans.org/topp',
>> extractAttributes: true,
>> controls: controls
>> Is the code above correct? Did I understand correctly or do I have to add
>> this control to the map as the other controls?
>> I'll try it out and let you know in case I have any problem. If it works
>> I'll post the solution.
>> Guillermo
>> On Mon, Dec 8, 2008 at 1:30 PM, Adorian Ardelean <mynature at gmail.com>wrote:
>>> Hi Guillermo,
>>> Look if you can use:
>>> *feature.attributes["city_name"]*
>>> example
>>> featureinfo = function(feature)
>>> alert(*feature.attributes["city_name"])*;
>>> controls = {
>>> All the best,
>>> Adorian
>>> On Mon, Dec 8, 2008 at 12:37 PM, Guillermo Lopez Mackinnon <
>>>> Thanks for your reply!
>>>> Actually, I meant the feature attributes like for instance "city_name",
>>>> "population" and so on. I´d like to display some of them when the user
>>>> clicks on a feature and since I may have several layers, doing it in the way
>>>> I explained in my initial post it'll be pretty tedious so I'd say it should
>>>> be some other way (a correct way) of doing this kind of stuff. Am I right?
>>>> Thanks again for your help!
>>>> Guillermo
>>>> On Mon, Dec 8, 2008 at 11:40 AM, Adorian Ardelean <mynature at gmail.com>wrote:
>>>>> Hi Nino,
>>>>> Do you mean all nodes of a polygon? If yes, you could explore Vector
>>>>> Formats Example in http://openlayers.org/dev/examples/ where is shows
>>>>> also how you could output coordinates of a feature in various formats.
>>>>> All the best,
>>>>> Adorian
>>>>> On Mon, Dec 8, 2008 at 11:24 AM, Nino Saturnino Martinez Vazquez Wael
>>>>> <nino.martinez at jayway.dk> wrote:
>>>>>> How can I extract all points for a geometry?
>>>>>> http://dev.openlayers.org/releases/OpenLayers-2.7/doc/apidocs/files/OpenLayers/Geometry/Collection-js.html#OpenLayers.Geometry.Collection
>>>>>> , do I need to call a field directly?
>>>>>> -Wicket for love
>>>>>> Nino Martinez Wael
>>>>>> Java Specialist @ Jayway DK
>>>>>> http://www.jayway.dk
>>>>>> +45 2936 7684
>>>>>> _______________________________________________
>>>>>> Users mailing list
>>>>>> Users at openlayers.org
>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>> Dr. Adorian Ardelean
>>>>> coordinator of myNature Project
>>>>> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
>>>>> biodiversity-database]
>>>>> http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
>>>>> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081208/2fa7f60c/attachment.html
