[OpenLayers-Users] Problem in displaying GML layer
Frank Broniewski
brfr at metrico.lu
Tue Dec 9 09:00:12 EST 2008
On Tuesday 09 December 2008 11:36:54 S.Reena wrote:
> Hi All,
> I want to upload gpx file on my map but its giving error that it cannot be
> displayed. I am attaching my gpx file with this
> map.addLayer(new OpenLayers.Layer.GML("GPX", "gpx/mygps.gpx",
> format: OpenLayers.Format.GPX,
> formatOptions:{ extractWaypoints:true,
> extractTracks:true,
> extractRoutes:true,
> extractAttributes:true
> http://www.nabble.com/file/p20912231/mygps.gpx mygps.gpx
> Thanks in advance :)
> Cheers,
> Reena.
Hi Reena,
I can't see anything wrong with your layer definitions, I am basically using
the same. Did you check your permissions on the gpx file (read)? Is the path
correct? Did you check if your gpx file is valid?
I am using the definition below, maybe it helps you.
Frank
pt = new OpenLayers.Layer.GML (
"Informationen",
"http://clydeswelt.frabron.de/kml/wpt.gpx",
projection: new OpenLayers.Projection("EPSG:4326"),
styleMap: ptStyle,
formatOptions: {
extractWaypoints: true,
extractTracks: false,
extractRoutes: false,
extractAttributes: true
Frank Broniewski
Metrico s.àr.l. ( http://www.metrico.lu )
36, rue des Romains
L-5433 Niederdonven
Luxembourg
Fon: +352 26 74 94 28
Fax: +352 26 74 94 99
