[OpenLayers-Users] Oracle Spatial and GML
Obe, Regina
robe.dnd at cityofboston.gov
Thu Dec 18 14:26:34 EST 2008
Or you could just dump Oracle and go with PostGIS which has AsWKT, AsGML and AsGeoJSON
and too many other functions to itemize -
http://postgis.refractions.net/documentation/manual-svn/ch07.html
Though I guess it depends what you need Oracle Locator for. If your whole application stack relies on an Oracle database, then I guess PostGIS might not be an option.
-----Original Message-----
From: users-bounces at openlayers.org on behalf of Sparks, Witt
Sent: Thu 12/18/2008 2:19 PM
To: Christopher Schmidt
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] Oracle Spatial and GML
Yeah, I'd rather use WKT, but as far as I can tell oracle's get_WKT()
function only comes with spatial. We're currently using Locator, which
is a subset of spatial included free with oracle.
I may end out buying spatial...
Thanks for your help!
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Thursday, December 18, 2008 11:56 AM
To: Sparks, Witt
On Thu, Dec 18, 2008 at 11:50:46AM -0700, Sparks, Witt wrote:
> Thanks for the (incredibly quick) response.
> Looking at the oracle spatial docs more closely, you're right, it says
> that SDO_UTIL.TO_GMLGEOMETRY produces a "GML fragment."
> I'll look around and see if there's a way I can get oracle to produce
a
> full GML document. I'll respond again if I find something.
Since your'e just using the Geometry, I'd really go for WKT --
serializing a 'full' GML document for geometry seems unneccesary. If you
are going to actually get the database to give you attributes to go
along with it, however, something like GML (or GeoJSON) seem like a good
idea.
I'm assuming you're taking the output from Oracle and pushing it through
some web application framework; at that point, you could wrap your
geometry in a featureMember, and stick in the properties as well, which
might help you get the feature you want.
> Thanks.
> Sent: Thursday, December 18, 2008 9:47 AM
> To: Sparks, Witt
> On Thu, Dec 18, 2008 at 09:31:20AM -0700, Sparks, Witt wrote:
> > Hello,
> > I'm trying to select GML from an oracle spatial table and use it to
> > create an OpenLayers.Feature.Vector object.
> > Oracle is giving me the following GML (for a point layer):
> This is a single Geometry; OpenLayers, generally speaking, parses
> features or feature collections. I believe the GML parser will only
work
> on FeatureCollections by default. Can you produce a featureCollection
> including this point?
> > <gml:Point srsName="SDO:8307"
xmlns:gml="http://www.opengis.net/gml">
> > <gml:coordinates decimal="." cs="," ts=" ">-94.653001,41.497753
> > </gml:coordinates>
> > </gml:Point>
> Regards,
> Christopher Schmidt
> MetaCarta
Christopher Schmidt
MetaCarta
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081218/c0b52bb9/attachment.html
