[OpenLayers-Users] Multiple projections in the same map
Thomas Rokkjaer thomas.rokkjaer at gmail.com
Fri Dec 26 03:58:59 EST 2008
Hi
I am not using OpenLayers anymore, since we developed our own webGIS.
I cannot remember what was the cause of the problem with using
multiple projections. However the use of map layers with different
projections is pretty straightforward. Sometimes you datasource comes
in different projections and you dont want the hassle of transforming
the maps.
Med venlig hilsen
Thomas Rokkjær
Niras Informatik
30950774
Den 26/12/2008 kl. 05.06 skrev "Eric Lemoine (via Nabble)" <ml-user+64477-1416789177 at n2.nabble.com
> On Jan 15, 2008 1:44 PM, Thomas Rokkjaer <thomas.rokkjaer at ...> wrote:
> > Does a working example with layers with different projections in
> the same map
> > exist?
> > I am trying to create a simple demo page consisting of the basic WMS
> > OpenLayers layer and a local projection layer from a GeoServer
> without
> > success.
> You can override the map projection at the layer level. For that, just
> set the projection option at layer creation time. In this way, you can
> have layers with different projections.
> By the way, why would you want layers with different projections in
> the same map?
> Eric
> Users mailing list
> Users at ...
> http://openlayers.org/mailman/listinfo/users
> This email is a reply to your post @ http://n2.nabble.com/Multiple-projections-in-the-same-map-tp1827057p1827058.html
> You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Multiple-projections-in-the-same-map-tp1827057p1863520.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081226/83e1f7f5/attachment.html
