[OpenLayers-Users] display lat/long data (kml, etc);
map not in epsg:4326
Christopher Schmidt
crschmidt at metacarta.com
Wed Jan 9 14:57:58 EST 2008
On Wed, Jan 09, 2008 at 02:54:23PM -0500, Christopher Schmidt wrote:
> On Wed, Jan 09, 2008 at 09:28:20AM -0800, Paul McCullough wrote:
> > All,
> > How do I display lat/long data (kml, georss, etc) on a map control that is
> > not using the epsg:4326 projection?
> You can't, yet. But you will be able to in 2.6. The thing you want to do
> is add reprojection calls after data is loaded in the Layer.GeoRSS and
> other classes. I plan to work on this as a patch -- maybe over the
> weekend? -- but haven't had a chance yet.
If your'e interested in taking over the task, I'll mentor you through it
-- in that case, follow up on dev, and I'll put together some pointers
on what we should do.
Regards,
Christopher Schmidt
MetaCarta
