[OpenLayers-Users] Firefox help needed for google
sphericalMercator <OpenLayers.Bounds is not a constructor>
Linda_Rawson
linda.rawson at gmail.com
Thu Jan 10 15:49:23 EST 2008
I found the solution. It seems there is a slight difference in the DOM
between the two browsers.
function loadScript(path, notCtx) {
var url = urlPath(path, notCtx);
// Internet Explorer
if (navigator.appName.indexOf("Microsoft") == 0) {
document.write ('<' + 'script src="' + url + '"'+'
type="text/javascript"><' + '/script>');
} else {
var element = document.createElement('script');
// set the 'src' attribute of the element
element.setAttribute('src', url);
element.setAttribute('type', 'text/javascript');
// insert the new node into the current document
document.getElementsByTagName("head")[0].appendChild(element);
function init() {
var sloc = "";
var SCRIPT_NAME = "googleKey.js";
var scripts = document.getElementsByTagName('script');
for (var i = 0; i < scripts.length; i++) {
var src = scripts[i].getAttribute('src');
if (src) {
var index = src.lastIndexOf(SCRIPT_NAME);
// is it found, at the end of the URL?
if ((index > -1) && (index + SCRIPT_NAME.length == src.length)) {
sloc = src.slice(0, -SCRIPT_NAME.length);
break;
____path = sloc;
loadScript(GOOGLE_TILES_SERVER + GOOGLE_TILES_KEY, true);
Linda
Linda_Rawson wrote:
> Ok. I need the ability to load the googlekey outside the default page.
> So in sphericalMercator.html it is loaded this way:
> <script
> src='http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ'></script>
> I created this file called google.js which is the following:
> var
> GOOGLE_TILES_KEY="ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ";
> var GOOGLE_TILES_SERVER="http://maps.google.com/maps?file=api&v=2&key=";
> var ____path = "";
> function urlPath(path, notCtx) {
> var incCtx = notCtx || false;
> var url = (!incCtx ? ____path : "") + path;
> return url;
> function init() {
> var sloc = "";
> if (src) {
> break;
> ____path = sloc;
> init();
> This works fine in internet explorer but in firefox I get:
> Any ideas?
> Linda Rawson
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Firefox-help-needed-for-google-sphericalMercator-%3COpenLayers.Bounds-is-not-a-constructor%3E-tp14724839p14743368.html
