[OpenLayers-Users] Controls and map events
Attila Csipa plists at prometheus.org.yu
Fri Jan 11 08:49:20 EST 2008
On Thursday 10 January 2008 12:29:26 Eric Lemoine wrote:
> Since pretty soon, the drag handler has a stopDown API property that
Now that's what I call bleeding edge :)
> one can set to allow/disallow event propagation. You can try to do
> dragControl.dragHandler.stopDown = true. Currently, there's no way to
OK, I'm a bit confused here: stopDown = true _allows_ or disallows event
propagation ? True is noted as the default and, interpreting the docs, stops
(disallows) event propagation - (as the code itself is propagate
= !this.stopDown;). From the svn log (and your message above) OTOH I'm under
the impression it's the other way around. In any case (in mine DragHandler
and a 'click' Map.Event above a feature), I've tried setting both true/false
manually but that did not change much as (according to my admittedly poor
firebug skills) the event still gets stopped in somebodys
OpenLayers.Handler.Feature (maybe it needs a stopDown property, too, or
modification to a common ancestor ?).
PS sorry if this is too technical, feel free to reply on -dev if it seems more
appropriate.
