[OpenLayers-Users] Pink Tile Killing Me
Arnd Wippermann arnd.wippermann at web.de
Mon Jan 14 13:29:58 EST 2008
I have the same problem with IE and OL. When IE failed to load a tile, it
shows the pink background. Then after some attempt(s) the tile will load,
but the pink background don't vanish. I use png as output format, but I have
also tried with gif. But it is the same behaviour.
http://www.panoramio.com/photo/7120030
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Lee Keel
Gesendet: Samstag, 12. Januar 2008 22:31
An: users at openlayers.org
Betreff: [OpenLayers-Users] Pink Tile Killing Me
Hello list.  I am having a problem with pink tiles.
Configuration:
 I am using OL 2.5, that I download from the link at
http://www.openlayers.org/api/OpenLayers.js, with ms4w beta from Sept 10.
Running against Postgres.
Problem:
I am getting a pink tile from my wms layers in ie, but the problem is that
they show at different times.  Once the pink tile turns on for that layer,
its always there.  So for example, one of the layers the pink tile comes on
when zoomed to max extents, any other resolution for that layer returns data
just fine.  But once you have zoomed to max extents and get the pink tile,
if you zoom in, the pink tile is there but there is also data.
What I have Tried:
The layer has no max extents in the map file, nor a max extent when layer is
added to OL.  I have set all the resolutions and I have removed all the
resolutions.  I have changed all sorts of settings, but can't seem to find
the problem.  I have a sample application, that doesn't use ol.  I have
tested that the data does render through this sample app, so I know the data
is coming from mapserver just fine.
I am open to any and all recommendations.  I was suppose to have this
completed yesterday, but this is my last hurdle.  Granted it is one big
hurdle.
Thanks in advance,
Lee
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
