[OpenLayers-Users] WFS-T delete/update
Arnaud Cogoluegnes acogoluegnes at sqli.com
Wed Jan 16 07:19:39 EST 2008
Thanks for your replies.
I found some hints for the update by analysing the GML request. Seems the
layer is incorrect in the request:
<wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" version="1.0.0"
service="WFS">
<wfs:Update typeName="features">
Indeed, "features" is not the layer address. With the correct typeName
(G4WD:tasmania_water) it worked (I tried with the GeoServer request demo
form).
Here some snippets of my code:
/* getting the layer */
var water = new OpenLayers.Layer.WFS(
  "Water",
  "/geoserver/wfs",
  {typename: 'G4WD:tasmania_water'},
    typename: 'tasmania_water',
    featureNS: 'http://www.mapmap.org/g4wd',
    extractAttributes: false
/* the modify control */
/* first some options */
var modifyOptions = {
    onModificationStart: function(feature) {
        OpenLayers.Console.log("start modifying", feature.id);
    onModification: function(feature) {
        OpenLayers.Console.log("modified", feature.id);
    onModificationEnd: function(feature) {
        OpenLayers.Console.log("end modifying", feature.id);
        /* the UPDATE state is modified here!!!! */
        feature.state = OpenLayers.State.UPDATE;
    onDelete: function(feature) {
        OpenLayers.Console.log("delete", feature.id);
var modify = new OpenLayers.Control.ModifyFeature(water,modifyOptions);
map.addControl(modify);
I then use the commit method of the WFS layer. So, anything I missed in the
use of OpenLayers API?
Thanks!
Arnaud
-----Message d'origine-----
De : users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] De
la part de Pierre GIRAUD
Envoyé : mercredi 16 janvier 2008 11:49
À : Yingqi
Cc : users at openlayers.org
Objet : Re: [OpenLayers-Users] WFS-T delete/update
Hi Arnaud,
I didn't use the WFS-T functionnalities for a long time now. I hope I
can throw an eye on it, but I don't think I will have time soon.
However, don't hesitate to send snippets of code so that I can
reproduce your test case.
Regards,
Pierre
On Jan 16, 2008 9:06 AM, Yingqi <anakintang at gmail.com> wrote:
> I think you should probably dig into OpenLayers\Format\GML.js to see if
fid
> is correctly retrieved when GML response from Geoserver was parsed when
you
> turned the layer. I guess fid attribute in your features are empty.
> Arno wrote:
> > Hi all,
> > I've been trying the WFS-T support for inserting polygons and it works
> > greats (polygons added in the PostGIS database, using GeoServer 1.6). I
> > tried also modifying features with the ModifyFeature Controls (based on
> > the
> > online example). Using the modifyOptions, I changed the state of the
> > feature:
> > and then tried to commit the WFS layer. But I received an error from the
> > GeoServer (log traces something like "features is not available") and
the
> > transaction failed. Before asking something on the GeoServer list, is
> > there
> > anything I missed when trying to modify the feature with OpenLayers?
> > For deleting, I used the SelectFeature control, overrode the onSelect
> > method
> > to mark the feature as deleted:
> > feature.state = OpenLayers.State.DELETE;
> > and when committing the WFS layer, OpenLayers displayed a message saying
> > that the fid was missing. Same as the update question, is there anything
I
> > missed when trying to mark the feature?
> > Thanks!
> > Arnaud
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
http://www.nabble.com/WFS-T-delete-update-tp14843989p14873181.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
Users mailing list
