[OpenLayers-Users] Selecting polygon error.
Eric Lemoine
eric.c2c at gmail.com
Fri Jan 18 12:12:49 EST 2008
On Jan 18, 2008 9:50 AM, Pierre GIRAUD <bluecarto at gmail.com> wrote:
> Sorry, I have no clue.
> I tested the following code (adapted from yours) in the
> select-feature.html example [1] and it worked great :
That it exactly why I suggested to try with the onSelect and
onUnselect callbacks removed. I'm suspecting that there's something
that causes the issue in the callbacks.
> var polygonAreaPoints = [
> new OpenLayers.Geometry.Point(0, 0),
> new OpenLayers.Geometry.Point(10, 0),
> new OpenLayers.Geometry.Point(10, 10),
> new OpenLayers.Geometry.Point(0, 10)
> var pointArray = [];
> for ( var j = 0; j < polygonAreaPoints.length; j++ )
> var x = polygonAreaPoints[j].x;
> var y = polygonAreaPoints[j].y;
> pointArray.push( new OpenLayers.Geometry.Point( x, y ) );
> // Create the linear ring
> var ring = new OpenLayers.Geometry.LinearRing( pointArray );
> // Create the polygon
> var feature = new OpenLayers.Geometry.Polygon( ring );
> var f = new OpenLayers.Feature.Vector(feature);
> map.layers[1].addFeatures( f );
> var polySelected = function() {
> console.log("selected");
> var polyUnselected = function() {
> console.log("unselected");
> selectControl = new OpenLayers.Control.SelectFeature(map.layers[1],
> {hover: true,
> onSelect: polySelected,
> onUnselect: polyUnselected});
> map.addControl( selectControl );
> selectControl.activate();
> [1] http://openlayers.org/dev/examples/select-feature.html
