[OpenLayers-Users] OL and VirtualEarth commercial
Till Adams
adams at terrestris.de
Mon Jan 21 10:21:06 EST 2008
Christopher Schmidt schrieb:
>>>On Thu, Jan 17, 2008 at 11:50:54AM +0100, Till Adams wrote:
>>>>dear list,
>>>>we build an application, where the background-maps for our OL client are served by MS VE (this was not my decision ;-)).
>>>>Now we have a commercial access (username/password) to MS VirtaulEarth - has anyone integrated commercial VE access in OL yet? Is there sth. like that key for google where I have to send username/password?
>>>No clue. If you find VirtualEarth documentation for how to connect, then
>>>share a link to that, someone might be able to advise how to implement
>>>it in OpenLayers. I'm not aware of any comercial VE usage inside OL at
>>>this time.
>>>Regards,
>>Chris, List,
>>thanks for your reply. Our reseller found out, the access is nearly the
>>same, they pointed us to
>>this:
>>http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6&mkt=somekey
>>Which is exactly the same, the in OL included "mapcontrol.js" does. As
>>long as I use "URL?v=3" or "URL?v=4" which
>>means older versions of VE, OL works. When I try v=5 or v=6 I get an
>>error pointing to "Msn.VE.Pixel".
>>I guess they result from a changing in the objectmodel of MS VE.
>>Does anyone ever used the newer versions of VE OR has anybody a clue
>>about how much adapting is needed,
>>to re-write the VE-access for OL to newer versions of MS VE?
>Some people have looked into it. I'm not one of them, and I don't
>remember hearing any specific information back on what the resolution
>was. I doubt that there would be much in the way of changes: the VE
>Layer is most likely easily adapted, and the change is likely just a
>change in names, not in functionality, but I'm not sure.
>The code to look at is OpenLayers.Layer.VirtualEarth.
>Regards,
Chris,
thanx, indeed, it doesn't look like too much stuff.
We'll see - if we adapt it, I 'll report and track back.
Till
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
