[OpenLayers-Users] Problem wth ScaleBar
Tim Schaub
tschaub at openplans.org
Mon Jan 28 16:06:11 EST 2008
Hey-
Tim Schaub wrote:
> Hey-
> Can you send me a bit more context? If you can't provide a link to a
> live site, but can send a page (or pages), send directly to me.
Sorry, and browser info.
> Thanks,
> Tim
> David R Robison wrote:
>> It looks like I have the right code. I think the problem is with the
>> styleValue routine. I have had to modify the following code in the draw
>> function:
>> var vertDisp = 0;
>> for(var classIndex = 0; classIndex < classNames.length;
>> ++classIndex) {
>> var cls = classNames[classIndex];
>> vertDisp = Math.max(
>> vertDisp,
>> this.styleValue(cls, 'top') + this.styleValue(cls, 'height')
>> if (vertDisp == 0) vertDisp = 30;
>> The vertDisp value was coming out to be zero. By adding the last line
>> and setting it to 30 it helped, but the bar still looks a bit off. I
>> load a number of style sheets and I think that there is an issue with
>> one that is causing the problem. I suspect the following code in styleValue:
>> if(typeof(sheet.cssRules) == 'undefined') {
>> if(typeof(sheet.rules) == 'undefined') {
>> // can't get rules, assume zero
>> break;
>> } else {
>> allRules = sheet.rules;
>> } else {
>> allRules = sheet.cssRules;
>> I am wondering if the "break;" should be a "continue;"? Any thoughts? David
>> Tim Schaub wrote:
>>> Hey-
>>>> I was using the one in the tschaub sandbox. David
>>> If you take a look at the patch for the scale bar, you'll see there are
>>> some changes required to the default stylesheet.
>>> http://trac.openlayers.org/attachment/ticket/24/scalebar.patch
>>> In addition, you'll want to add your stylesheet with a link tag instead
>>> of relying on the default dynamically added stylesheet.
>>> <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
>>> Thanks for trying it out. Write back if you still have any trouble with it.
>>> Tim
>>>> Christopher Schmidt wrote:
>>>>> On Mon, Jan 21, 2008 at 06:43:27PM -0500, David R Robison wrote:
>>>>>> I am trying to get the OpenLayers.Control.ScaleBar working. I've added
>>>>>> it to my map according to the example html. However, when my map draws,
>>>>>> I get the units (in my case 'miles') but it displays at the bottom of
>>>>>> the map and I get no scale bar. Its as if the scale bar is below the map
>>>>>> and hidden. Any thoughts on how to get this to work correctly? Thanks, David
>>>>> Are you adding ScaleBar (which isn't in trunk) or Scale()? OpenLayers
>>>>> does not currently have a ScaleBar control.
>>>>> Regards,
>>>> David R Robison
>>>> Open Roads Consulting, Inc.
>>>> 708 S. Battlefield Blvd., Chesapeake, VA 23322
>>>> phone: (757) 546-3401
>>>> e-mail: drrobison at openroadsconsulting.com
>>>> web: http://openroadsconsulting.com
>>>> blog: http://therobe.blogspot.com
>>>> book: http://www.xulonpress.com/book_detail.php?id=2579
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
>> David R Robison
>> !DSPAM:4033,479e3dc020313362379201!
> Users mailing list
> !DSPAM:4033,479e436033035219720167!
