[OpenLayers-Users] Problem wth ScaleBar
David R Robison
drrobison at openroadsconsulting.com
Mon Jan 28 16:49:51 EST 2008
Firefox 2.0.0.11 - I will need to check the stylesheets... David
Tim Schaub wrote:
> Hey-
> David R Robison wrote:
>> Found the problem. I have 10 style sheets loaded into the application.
>> When processing the first, the access to cssRules through the error:
>> NS_ERROR_DOM_INVALID_ACCESS_ERR. This error caused the other style
>> sheets to be ignored. If I replaced the "break" in the catch block with
>> "continue", all was well. David
> Yeah, I guessed it was something like that. Can you mention the name of
> your browser? And perhaps give an indication of how your stylesheets
> are included/linked? Do any of your stylesheets have no rules in them?
> I'm curious to see where sheet.cssRules is undefined for one
> stylesheet but not the next.
> The patch for #24 is updated. Thanks for any more info.
> Tim
>> Tim Schaub wrote:
>>> Hey-
>>> Tim Schaub wrote:
>>>> Hey-
>>>> Can you send me a bit more context? If you can't provide a link to a
>>>> live site, but can send a page (or pages), send directly to me.
>>> Sorry, and browser info.
>>>> Thanks,
>>>> Tim
>>>>> It looks like I have the right code. I think the problem is with the
>>>>> styleValue routine. I have had to modify the following code in the draw
>>>>> function:
>>>>> var vertDisp = 0;
>>>>> for(var classIndex = 0; classIndex < classNames.length;
>>>>> ++classIndex) {
>>>>> var cls = classNames[classIndex];
>>>>> vertDisp = Math.max(
>>>>> vertDisp,
>>>>> this.styleValue(cls, 'top') + this.styleValue(cls, 'height')
>>>>> if (vertDisp == 0) vertDisp = 30;
>>>>> The vertDisp value was coming out to be zero. By adding the last line
>>>>> and setting it to 30 it helped, but the bar still looks a bit off. I
>>>>> load a number of style sheets and I think that there is an issue with
>>>>> one that is causing the problem. I suspect the following code in styleValue:
>>>>> if(typeof(sheet.cssRules) == 'undefined') {
>>>>> if(typeof(sheet.rules) == 'undefined') {
>>>>> // can't get rules, assume zero
>>>>> break;
>>>>> } else {
>>>>> allRules = sheet.rules;
>>>>> } else {
>>>>> allRules = sheet.cssRules;
>>>>> I am wondering if the "break;" should be a "continue;"? Any thoughts? David
>>>>> Tim Schaub wrote:
>>>>>> Hey-
>>>>>>> I was using the one in the tschaub sandbox. David
>>>>>> If you take a look at the patch for the scale bar, you'll see there are
>>>>>> some changes required to the default stylesheet.
>>>>>> http://trac.openlayers.org/attachment/ticket/24/scalebar.patch
>>>>>> In addition, you'll want to add your stylesheet with a link tag instead
>>>>>> of relying on the default dynamically added stylesheet.
>>>>>> <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
>>>>>> Thanks for trying it out. Write back if you still have any trouble with it.
>>>>>> Tim
>>>>>>> Christopher Schmidt wrote:
>>>>>>>> On Mon, Jan 21, 2008 at 06:43:27PM -0500, David R Robison wrote:
>>>>>>>>> I am trying to get the OpenLayers.Control.ScaleBar working. I've added
>>>>>>>>> it to my map according to the example html. However, when my map draws,
>>>>>>>>> I get the units (in my case 'miles') but it displays at the bottom of
>>>>>>>>> the map and I get no scale bar. Its as if the scale bar is below the map
>>>>>>>>> and hidden. Any thoughts on how to get this to work correctly? Thanks, David
>>>>>>>> Are you adding ScaleBar (which isn't in trunk) or Scale()? OpenLayers
>>>>>>>> does not currently have a ScaleBar control.
>>>>>>>> Regards,
>>>>>>> David R Robison
>>>>>>> Open Roads Consulting, Inc.
>>>>>>> 708 S. Battlefield Blvd., Chesapeake, VA 23322
>>>>>>> phone: (757) 546-3401
>>>>>>> e-mail: drrobison at openroadsconsulting.com
>>>>>>> web: http://openroadsconsulting.com
>>>>>>> blog: http://therobe.blogspot.com
>>>>>>> book: http://www.xulonpress.com/book_detail.php?id=2579
>>>>>>> _______________________________________________
>>>>>>> Users mailing list
>>>>>>> Users at openlayers.org
>>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>>> Users mailing list
>>>>> David R Robison
>>>> Users mailing list
>>>> !DSPAM:4033,479e436033035219720167!
>>> Users mailing list
>> David R Robison
>> !DSPAM:4033,479e4b1f56767082231907!
> Users mailing list
David R Robison
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080128/e4a05e45/attachment.html
