[OpenLayers-Users] Cannot upgrade to 2.6 because of vector lines disappearing in IE (Frustrated)
Linda Rawson linda.rawson at gmail.com
Wed Jul 2 03:50:00 EDT 2008
Yes it does!  Thanks!
On Wed, Jul 2, 2008 at 1:32 AM, Andreas Hocevar
<andreas.hocevar at gmail.com> wrote:
> Linda,
> On Wed, Jul 2, 2008 at 1:40 AM, Linda Rawson <linda.rawson at gmail.com> wrote:
>> I so wish this had taken care of the problems.  But I am still having problems.
>> The example looks complex but in actuality it is simply 8 linestring
>> features on a vector layer.
>> When the example starts you see line 1.  You can zoom5, zoom6, zoom7,
>> zoom8 all day.  Works great.
>> Then I push the button called Line 1.  It should zoom to where line 1
>> is.  It does.  But the line does not show until I push zoom5 button
>> which simply does a zoomtoscale.  The same with all the other lines.
>> Something about setcenter is not making the lines appear.
> Please try if the patch from http://trac.openlayers.org/ticket/1602
> solves your problem.
> Regards,
> Andreas.
Linda Rawson
