[OpenLayers-Users] GeoRSS
Fabio D'Ovidio
fabiodovidio at gmail.com
Fri Jul 4 10:01:07 EDT 2008
Hi!
I read openlayers 2.6 improved GeoRSS Format support, including GeoRSS
GML read support
http://trac.openlayers.org/wiki/Release/2.6/Announce/Final
I assume, in order to display polygon and line GeoRSS, I must create an
OpenLayers.Layer.Vector layer with the features created from the feed
using OpenLayers.Format.GeoRSS.read.
I can't use OpenLayers.Layer.GeoRSS. Is it right?
Could another solution be as following?
var georssformat = new OpenLayers.Format.GeoRSS;
var gmllayer = new OpenLayers.Layer.GML("Test", "rss.xml",
{'format': georssformat});
Thanks
Paul Spencer ha scritto:
> Please check the OpenLayers examples that come with the source
> package, you will find everything you need.
> On 3-Jul-08, at 5:02 AM, Fabio D'Ovidio wrote:
>> Hi!
>> Does OL support GeoRSS polygon and\or line geometries in the new
>> version?
>> Any example?
>> Ing. Fabio D'Ovidio
>> INOVA Open Solutions s.r.l.
>> Web : http://www.inovaos.it
>> Tel.: 081 197 57 600
>> mail: fabiodovidio at gmail.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
