[OpenLayers-Users] Transitional / Intermediate Zoom Levels
bartvde at osgis.nl
bartvde at osgis.nl
Tue Jul 8 02:31:22 EDT 2008
Hi Lance,
it's called fractionalZoom and is a property on the map object. Available
since 2.6.
* Property: fractionalZoom
* {Boolean} For a base layer that supports it, allow the map
resolution
* to be set to a value between one of the values in the
resolutions
* array. Default is false.
* When fractionalZoom is set to true, it is possible to zoom to
* an arbitrary extent. This requires a base layer from a source
* that supports requests for arbitrary extents (i.e. not cached
* tiles on a regular lattice). This means that fractionalZoom
* will not work with commercial layers (Google, Yahoo, VE), layers
* using TileCache, or any other pre-cached data sources.
* If you are using fractionalZoom, then you should also use
* <getResolutionForZoom> instead of layer.resolutions[zoom] as the
* former works for non-integer zoom levels.
fractionalZoom: false,
Best regards,
Bart
On Mon, 07 Jul 2008 23:44:29 -0500, Lance Dyas <lancelot at inetnebr.com>
wrote:
> I seem to recall a post about intermediate zoom levels
> I think it was a sandbox item. But I had the impression
> it was only worked for WMS.. (which is rather a noteable
> limit) Ive been trying to find it, without luck anyone know
> what I am talking about?
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
