[OpenLayers-Users] Difficulties with GetFeatureInfo
Rick Wayne
fewayne at wisc.edu
Tue Jul 8 16:01:07 EDT 2008
Hullo all,
I'm using OpenLayers and GeoServer, and am having some trouble with
getting XML data out of GetFeatureInfo. If I ask GeoServer for
INFO_FORMAT of application/vnd.ogc.gml, I get a response back, and it
has the data I desire. But I cannot access those data as XML. I have
to get them via responseText and parse that looking for angle brackets
and the like, which is all very boring, not to say fragile as a dried
leaf.
Of course, I should be able to make use of the responseXML property,
but that obstinately persists in being NULL, even when the text
response is fine. In fact, the text response is perfectly good XML. As
a big honkin' string.
I'm using GeoServer 1.5.3 and, er, whichever OL version came with
that. :-)
Below are the relevant calls. If anyone can assuage my ignorance, good
cheer to them!
TIA,
Rick Wayne
UW Soil Science
map.events.register('click', map, function (e) {
var url = map.baseLayer.getFullRequestString({
REQUEST: "GetFeatureInfo",
EXCEPTIONS: "application/vnd.ogc.se_xml",
BBOX: map.getExtent().toBBOX(),
X: e.xy.x,
Y: e.xy.y,
INFO_FORMAT: 'application/vnd.ogc.gml',
// INFO_FORMAT: 'text/plain',
QUERY_LAYERS: map.baseLayer.params.LAYERS,
FEATURE_COUNT: 1,
srs: 'EPSG:26916',
styles: '',
layers: 'mmas:civil',
WIDTH: map.size.w,
HEIGHT: map.size.h},
"/geoserver/wms"
OpenLayers.loadURL(url, '', this, zoomToFeature, zoomToFeature);
Event.stop(e);
function zoomToFeature(response) {
// lines = response.responseText.split('\n');
var txt;
var tag;
var coord_index;
var rest;
var coord_text;
var coords;
var coord_pairs,ll,ur;
txt = response.responseText; // here should be xml =
response.responseXML;
tag = 'gml:coordinates decimal="." cs="," ts=" ">';
coord_index = txt.indexOf(tag);
rest = txt.substr(coord_index + tag.length);
end_coord_index = rest.indexOf('<');
// And so on, too ugly to reveal the rest!
