[OpenLayers-Users] Smooth transition between two Image layers
realjax
jax at schildmos.nl
Fri Jul 11 03:37:05 EDT 2008
Jesper-5 wrote:
> Is the solution to this to use Tween to create a smooth transition
> between to Layers? I tried it but I haven't been able to understand
> how to do it. I hope someone can help me out. What I tried is simply:
OpenLayers.Tween is not likely going to suit your needs.
I think you need to search for an external solution that has one layer fade
out while the other fades in. You could (with a bit of hacking) prolly get
this working in combination with a lightweight framework like Mootools for
example.
View this message in context: http://www.nabble.com/Smooth-transition-between-two-Image-layers-tp18381498p18398374.html
