[OpenLayers-Users] openlayers + tilecache + resolutions
Ivan Grcic
ivan.grcic at geofoto.hr
Sun Jul 13 08:52:31 EDT 2008
Hi, i think its something like this:
scale = resolution * OpenLayers.INCHES_PER_UNIT[1m] *OpenLayers.DOTS_PER_INCH
(you can set OpenLayers.DOTS_PER_INCH to some other number but default is 72)
scale = resolution * 39.3700787401575 * 72
resolution = 39.3700787401575 * 72 / scale
You just need to set zoom levels, like 1 000 000, 500 000, 100 000, 10
000...and calculate scales according to them...
Cheers!
On Thu, Jul 10, 2008 at 3:43 PM, Wendell Turner <wendell at enflight.com> wrote:
> How does someone compute the resulutions array? As I
> understand it, to make openlayers work well with tilecache,
> the zoom levels and resolutions all need to match. Also,
> maxResolution: "auto" is specifically bad for this reason.
> Given a mosaic of geotiff images in epsg:3394 (which is in
> meters), and knowing the (outer) bounding box of them, how
> do I compute the resolutions array so that the layers
> generated by tilecache_seed.py match those requested by
> openlayers?
> Thanks,
> Wendell
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Ivan Grcic
igrcic at gmail.com
Mobile (CRO): +385 98 576 457
