[OpenLayers-Users] AWS S3 Support for OpenLayers???
Paul Spencer
pagameba at gmail.com
Tue Jul 15 08:27:16 EDT 2008
Steve,
I think you would need a specific layer type that supports S3. If you
are using kaMap to generate the tiles (and the path to the tiles) then
you would probably want to start with the kaMap layer and modify or
subclass it to make the appropriate request directly from S3.
Conceptually, this is fairly trivial to do, you would just overload
the getURL function with something that generates a url to S3.
TileCache supports S3 as a cache, but I'm not sure if the TileCache
layer in OpenLayers can directly read them.
Cheers
Paul
On 15-Jul-08, at 12:40 AM, Stephen Woodbridge wrote:
> Hi,
> Does OpenLayers support Amazon S3 storage as a layer provider?
> If I generate ka-map style tiles and load them into S3 using the file
> path as the key, is there an easy way of serving these directly to an
> OpenLayers client?
> Thanks,
> -Steve W
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
