[OpenLayers-Users] proj4js question
Patrick Valsecchi patrick.valsecchi at camptocamp.com
Wed Jul 23 16:44:55 EDT 2008
On Wednesday 23 July 2008, you wrote:
> THis is not the case here. The input is checked, the developer is
> informed of the problem. This is not a proj4js library problem.
Never seen any logs. Here is the implementation of the log method that is
called when this error happens:
  log: function(msg) {
OK, I should have redefined this method and the "reportError" method.
Thanks.
