[OpenLayers-Users] Place popups over controls
Eric Lemoine eric.c2c at gmail.com
Sat Jul 26 14:17:17 EDT 2008
or just change that particular popup z-index to that value. Eric
2008/7/26, Erik Uzureau <euzuro at gmail.com>:
> did you try changing
> map.Z_INDEX_BASE.Popup = map.Z_INDEX_BASE.Control + 1;
> ?? seems like that should work
> Erik
> On 7/14/08, Daniel Kastl <orkney at gmx.de> wrote:
>> Hi List,
>> I'm looking for a way to solve the following problem:
>> When adding a feature to the map I want to open an OpenLayers popup to
>> add some attributes. This popup should cover most of the map div and add
>> some transparent layer over the map.
>> This works fine so far except that I cannot get the popup be on a higher
>> z-index than the control buttons, pan-zoom bar, etc.. It's still
>> possible to pan and zoom with the PanZoomBar, but I would like to
>> disable this while showing the popup
>> Is there a way to place the popup layer (temporary) on top of the
>> control layer? (I tried to change Z_INDEX_BASE but didn't have any effect)
>> Or is there an elegant way to temporary disable control events while
>> showing the popup?
>> (I'm using OL 2.6)
>> Thanks for your help,
>> Daniel
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
