[OpenLayers-Users] Include drop down box in popup that contains
query result
Arnd Wippermann
arnd.wippermann at web.de
Sun Jul 27 06:52:30 EDT 2008
you can do it on server-side with templates or client-side with javascript.
Server-side:
Create html templates for your query:
A Header template with:
<select>
A body template with:
<option value="[item1]">[item2]
And a Footer template with:
</select>
Then your query returns the HTML for a drop down box.
Client-side:
Create a body template that returns a list of the results:
[item1],[item2],[item3]
Then your query returns text, which you can transform with javascript into
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von S.Reena
Gesendet: Sonntag, 27. Juli 2008 11:37
An: users at openlayers.org
Betreff: [OpenLayers-Users] Include drop down box in popup that contains
query result
I have made popup in UMN openlayers. I want to make a dynamic drop down box
in it that shows result of the postresql database query. Can any one guide
me up as to what to use..Python or something else..
Cheers,
Reena.
View this message in context:
http://www.nabble.com/Include-drop-down-box-in-popup-that-contains--query-re
sult-tp18674744p18674744.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
