[OpenLayers-Users] Displaying lat long coordinates for
projected map?
Christopher Schmidt
crschmidt at metacarta.com
Sun Jul 27 10:58:21 EDT 2008
On Sun, Jul 27, 2008 at 06:56:35AM -0700, Matthew Perry wrote:
> Hi all,
> Has anyone had any success displaying latlong coordinates for a
> projected map? The relevant code is below... all I get is "Nan, Nan"
> in the coordinate display. Is there something obvious that I should
> try?
The spherical-mercator example displays unprojected coordinates using
this method with no problems.
If you do:
OpenLayers.Projection.transform({'x':10, 'y':10}, new
OpenLayers.Projection("EPSG:54009"), new
OpenLayaers.Projection("EPSG:4326"));
Do you get NaN as well? My guess would be 'yes'.
> ====== begin listing ========
> <script src="./lib/OpenLayers.js"></script>
> <script src="./lib/proj4js.js"></script>
> <script type="text/javascript">
> Proj4js.defs["EPSG:4326"] = "+proj=longlat +ellps=WGS84
> +datum=WGS84 +no_defs ";
> Proj4js.defs["EPSG:54009"] = "+proj=moll +lon_0=0 +x_0=0
> +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs";
> var map;
> function init(){
> map = new OpenLayers.Map( 'map',
> restrictedExtent: new
> OpenLayers.Bounds(-18040095,-9020047,18045393,9022696),
> maxExtent: new
> maxResolution: 37984.724210526314,
> projection: new
> OpenLayers.Projection("EPSG:54009"), // have also tried just the
> string "EPSG:54009"
> units: 'm',
> controls: [
> new OpenLayers.Control.PanZoomBar(),
> new OpenLayers.Control.Navigation(),
> new OpenLayers.Control.MousePosition(
> {displayProjection: new
> OpenLayers.Projection("EPSG:4326")}),
> new OpenLayers.Control.ScaleLine({units: 'mi'}),
> numZoomLevels: 8
> ====== end listing ========
> ·´¯`·.¸. , . .·´¯`·.. ><((((º>`·.¸¸.·´¯`·.¸.·´¯`·...¸><((((º>
> "The best way to predict the future is to invent it." -- Alan Kay
> Matthew T. Perry
> http://www.perrygeo.net
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
