[OpenLayers-Users] wfs stylemap example?
Alexandre Dube
adube at mapgears.com
Tue Jul 29 16:22:07 EDT 2008
Hi Todd,
I have some to share. My WFS layer contains line features ( roads ) and
they have different color depending on their type ( Local road, Highway,
etc ). I hope this can be of any help :
============= otherfile.js =============
// prepare to style the data
var oStyleMap = new OpenLayers.StyleMap();
// Array of symbolizer and other values for ROL_CO_CLA attribute
// this will be used to create a html select list and will be used
// as the symbolizer array for the addUniqueValueRules function
// sorry, there's some french words here :)
var aRoadType = new Array();
aRoadType = {
AUT: {
text: "Autoroute",
strokeColor: "#ff0000", strokeWidth: 3 },
NAT: {
text: "Nationale",
strokeColor:"#ff8c00", strokeWidth: 2 },
REG: {
text: "Régionale - Reg",
COL: {
text: "Régionale - Col",
ACC: {
text: "Locale - Acc",
strokeColor:"#d2b48c", strokeWidth: 2 },
LOC: {
text: "Locale - Loc",
ACH: {
text: "Chemin forestier - Ach",
strokeColor:"#734c00", strokeWidth: 2 },
MRN: {
text:"Chemin forestier - Mrn",
// a style will applies to each drawned vector feature depending on
// the ROL_CO_CLA attribute value. It will match the good value and applies
// the corresponding symbolizers
oStyleMap.addUniqueValueRules("default", "ROL_CO_CLA", aRoadType);
// If no rules applies to the current vector feature, that means it's
// not a road, but an other type of feature like a circle for drag
// control. The "elseFilter: true" is used to display those vectors.
var rules = [new OpenLayers.Rule({
symbolizer: {strokeColor:"#FF0000",strokeWidth: 2},
elseFilter: true
oStyleMap.styles["default"].addRules(rules);
============= yourHTMLFile.html =============
--- inside your <head> section ---
<script src="otherfile.js"></script>
--- inside your init() function ---
OpenLayers.Feature.Vector.style['default']['strokeWidth'] = '2';
// then some variables... map definition... base layer ... some WMS
layers ... and :
olWFSRoads = new OpenLayers.Layer.WFS(
"Roads - WFS", sMSURL,
{ typename: "roads", map: sMapPath },
{ extractAttributes: true, minScale: 49999,
typename: "roads", styleMap: oStyleMap
// then addlayers, controls, etc. and your <body>
Brenningmeyer, Todd wrote:
> Hello,
> Does anyone have an example code snippet that shows how to use a stylemap with wfs data that is being served as vectors (I'm trying to serve up points). I've been trying to get this to work using some of the examples on the wiki but I can't quite get the syntax to work properly. If anyone has ideas or an example that would be great.
> Thanks,
> Todd
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
