[OpenLayers-Users] OpenLayers.. Redraw
Mike Quentel mquentel at rim.com
Thu Jul 31 11:15:11 EDT 2008
Para salvar el estado del mapa (zoom, vector de coordenadas, posición, capa activa, etc), puede utilizar el formulario de entrada oculto valores como esto [to save the state from the map (zoom, vector coordinates, position, active layer, etc), you can use the entry form hidden values like this]:
<input type="hidden" id="zoom" name="zoom" value=""></input>
<input type="hidden" id="position" name="position" value=""></input>
...etc...
Mike Quentel
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On Behalf Of David Calle
Sent: Thursday, 31 July 2008 10:32
To: users at openlayers.org
Subject: [OpenLayers-Users] OpenLayers.. Redraw
Hi guys....
I need help on my project,  i'm using Open Layers with PostGis on my maps...
But i need help with the function redraw, for refresh my map without lose the zoom, the position and the active layers when i insert new data on Postgres...
OpenLayers.VERSION_NUMBER="$Revision: 6819 $";
Thans for your help..
PD.... if you can answer me in spanish...
This transmission (including any attachments) may contain confidential information, privileged material (including material protected by the solicitor-client or other applicable privileges), or constitute non-public information. Any use of this information by anyone other than the intended recipient is prohibited. If you have received this transmission in error, please immediately reply to the sender and delete this information from your system. Use, dissemination, distribution, or reproduction of this transmission by unintended recipients is not authorized and may be unlawful.
