[OpenLayers-Users] Fwd: Refresh html without losing,
what I've done
Alan Boudreault
aboudreault at mapgears.com
Thu Jul 31 15:26:24 EDT 2008
It can look like the following example......
<html>
<head>
<style type="text/css">
#map {
width: 900px;
height: 600px;
</style>
<title>Sistema de Trasporte Urbano - Cuenca Ecuador </title>
<script src="OpenLayers.js"></script>
<script type="text/javascript">
var map, zoomLevel, activeLayer, position;
var popup, feature, markers, marker;
var manzanas;
function init()
// Opciones base para el mapa
var mapOptions = {
maxExtent: new OpenLayers.Bounds(713620.5057, 9673754.1986,
732936.3635, 9687405.8116),
maxResolution: 'auto',
projection:"EPSG:32717",
//restrictedExtent: new OpenLayers.Bounds(713620.5057,
9673754.1986, 732936.3635, 9687405.8116),
units: "m"};
// Crear el objeto map
map = new OpenLayers.Map('map', mapOptions);
// Añadir controles de navegación
map.addControl(new OpenLayers.Control.LayerSwitcher());
var panel = new OpenLayers.Control.NavToolbar();
map.addControl(panel);
map.addControl(new
OpenLayers.Control.MousePosition({'div':OpenLayers.Util.getElement('coords')}));
var manzanas = new OpenLayers.Layer.MapServer.Untiled(
"manzanas", "../../cgi-bin/mapserv",
{map:'C:/data/publicacion.map',
layers: 'manzanas',map_imagetype: 'png'},
{'displayInLayerSwitcher':false});
var ruta22 = new OpenLayers.Layer.MapServer.Untiled( "Ruta 22",
{map:'C:/data/publicacion.map', transparent: "true",
layers: 'ruta22_ida',map_imagetype: 'png'},{'isBaseLayer':
false}, {'displayInLayerSwitcher':false});
var ruta8 = new OpenLayers.Layer.MapServer.Untiled( "Ruta 8",
layers: 'ruta8_ida',transparent: "true", map_imagetype: 'png'});
var paradas8 = new OpenLayers.Layer.MapServer.Untiled( "Paradas
8", "../../cgi-bin/mapserv",
layers: 'paradas8_ida',transparent: "true", map_imagetype:
'png'});
var paradas22 = new OpenLayers.Layer.MapServer.Untiled( "Paradas
22", "../../cgi-bin/mapserv",
layers: 'paradas22_ida',transparent: "true", map_imagetype:
'png'});
var recorridos = new OpenLayers.Layer.MapServer.Untiled(
"Unidad()", "../../cgi-bin/mapserv",
layers: 'recorrido',transparent: "true", map_imagetype: 'png'});
ruta22.setVisibility(false);
ruta8.setVisibility(false);
paradas22.setVisibility(false);
paradas8.setVisibility(false);
//recorridos.setVisibility(false);
map.addLayers([ruta22, ruta8, manzanas, paradas8, paradas22,
recorridos]);
if (!map.getCenter()) map.zoomToMaxExtent();
//set the timeout
setTimeout( "redrawLayers()", 10*1000 );
function redrawLayers()
//keep current zoomLevel etc... with the global variable "map"
//try to simply redraw your layers: "manzanas" is a global too
manzanas.redraw();
</script>
</head>
<body onLoad="init()">
<table>
<tr>
<td align="left"><div id="map"></div></td>
</tr>
</table>
</body>
</html>
Alan
