[OpenLayers-Users] (slightly) OT: css frameworks
Paul Spencer
pspencer at dmsolutions.ca
Fri May 2 08:03:03 EDT 2008
this is somewhat off topic, but since we are usually in the business
of putting maps into web pages, I usually find I have to put together
some kind of web page around the map and that's where I start running
into trouble. While limiting myself to plain HTML tags and avoiding
any kind of colour/style decisions is usually a wise idea, sometimes
its nice to put some effort into the web page beyond the absolute
minimum ...
For those of us that are, um, designed-challenged, using a CSS
framework is a great place to start. I've recently found a couple of
them that might be of interest:
http://code.google.com/p/blueprintcss/
"Blueprint is a CSS framework, which aims to cut down on your CSS
development time. It gives you a solid CSS foundation to build your
project on top of, with an easy-to-use grid, sensible typography, and
even a stylesheet for printing."
http://960.gs/
"The 960 Grid System is an effort to streamline web development
workflow by providing commonly used dimensions, based on a width of
960 pixels. There are two variants: 12 and 16 columns, which can be
used separately or in tandem."
Both frameworks provide a fixed column grid based on a fixed width of
960 pixels, and blueprint adds some decent choices for colors, styles
etc. The fixed width thing is often not what we want for mapping
sites built with OpenLayers (we want the map to fill the page and
these frameworks won't do that) but occasionally you need a different
approach.
I put together a simple (non-mapping) page using blueprint after about
5 mins of reading the tutorial and was pretty happy with the result.
I haven't tried 960.gs yet but it seems similar in concept and
probably more appropriate if you just want the layout part.
I haven't specifically researched other CSS frameworks so there's
probably something better out there if you care to look.
Cheers
Paul
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://www.dmsolutions.ca/
