[OpenLayers-Users] Make the base layer empty or blank
Matt Williamson matthewdw at gmail.com
Tue May 6 20:26:01 EDT 2008
Justin,
I've done something sort of like this before--I just made a small
transparent GIF image and set it as a Layer.Image as the base layer
(stretched to some arbitrary size and bounding box). You might even be
able to set it to not be visible in the Layer Switcher, but I forget
the property or method to set to try that (and it might not work). The
only thing you'll have to do is configure that "blank" image layer
with the appropriate scales or resolutions that you want your other
layers to conform to (or I think you can set these on the map
directly, but I haven't tried that yet).
Probably a better way, but that has at least worked for me.
-Matt
On May 6, 2008, at 5:25 PM, Justin Madex wrote:
> Hi
> Is there a way to make the base layer a blank map? The reasoning is
> that i have multiple layers, but i dont necessarily want to make any
> of them a base layer.
> The alternative is to set the base layer based upon what scale im
> currently at. If i have multiple base layers, is there a way to
> change which layer is the current base layer depending on the
> current scale i am at?
> Thanks for your help
> Justin
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
