[OpenLayers-Users] WFS points for markers and popups
Tom (JDi Solutions)
tom.dean at jdi-solutions.co.uk
Fri May 9 11:25:52 EDT 2008
Hi Robert, thanks for the quick response. I have looked at the 2 examples
you suggested and as far as I can see they are ideal for small datasets
which can be loaded all at once but I am using WFS specifically because the
dataset is fairly large (a few thousand points) and as such I only want
OpenLayers to request as much as the user is viewing on screen. When the
user zooms right out I'm going to remove them altogether so at any point
they will only see a hundred or so at most.
On Fri, May 9, 2008 at 3:42 PM, Burgholzer,Robert <
rwburgholzer at deq.virginia.gov> wrote:
> Tom,
> You may first want to look at the popups demo, popups.html and the
> textmarkers demo, markersTextLayer.html, in the example folder of the
> OpenLayers distro.
> It would seem that this would be fairly easy to add to a WMS layer.
> r.b.
> -----Original Message-----
> From: users-bounces at openlayers.org on behalf of Tom (JDi Solutions)
> Sent: Fri 5/9/2008 10:20 AM
> To: users at openlayers.org
> Cc:
> Subject: [OpenLayers-Users] WFS points for markers and popups
> Hi all,
> I've googled and searched the examples and mail archives for the solution
> for this but can't quite find precisely what I'm looking for so I wonder if
> someone could help out?
> I have so far managed to get a standard OpenLayers setup and added a WMS
> base layer and a WFS layer which returns 2 pieces of data, a point geometry
> (GEOLOC) and a site reference (SITE_REF) using the following code:
> var layer2= new OpenLayers.Layer.WFS('Points',
> 'http://mygeoserver/geoserver/wfs?' <http://mygeoserver/geoserver/wfs?%27>
> ,{request:'GetFeature',PropertyName:'GEOLOC,SITE_REF',typeName:'gndp:points',isBaseLayer:'false',extractAttributes:'true'});
> and that adds a layer of markers to the map which is great. What I now
> want
> is to add popups to these markers which simply displays the SITE_REF (I'll
> later change this to some slightly more glamorous HTML but for now that
> will
> do.
> It seems like I may have to use featureClass: OpenLayers.Feature.WFS as
> shown in the example here: http://openlayers.org/dev/examples/wfs.html but
> that appears to give the same functionality I already have. There is a
> suggestion to subclass OpenLayers.Feature.WFS in order to add a popup but
> my
> js skills are weak and I don't get how to do this. Can someone give an
> example? Which methods need to be overridden and how do I get my data into
> the popup?
> Furthermore, is it possible to load the WFS layer as a tiled layer so I can
> cache the results? and how do I set a different icon?
> thanks in advance,
> Tom
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080509/1ee85847/attachment.html
