[OpenLayers-Users] rules depending on state
Pierre GIRAUD
bluecarto at gmail.com
Tue May 13 10:56:42 EDT 2008
Yep,
I already tried that and this works great.
However, what if I want to set fillColor, strokeColor, fillOpacity and
strokeOpacity at the same time ? This is really painful.
And it seems like I need to provide a valid value for each possible
value of state. Default style won't be applied to features that aren't
in the switch cases.
I would prefer something like :
var lookup = {
'Insert': {
fillColor: 'green',
fillOpacity: 0.5
Regards,
Pierre
On Tue, May 13, 2008 at 4:35 PM, Andreas Hocevar
<andreas.hocevar at gmail.com> wrote:
> Hey Pierre,
> without having tried, something like the following should work:
> var context = {
> getStateColor: function(feature) {
> switch(feature.state) {
> case "Insert": return "green";
> case "Update": return "yellow";
> case "Delete": retrun "red";
> var styleMap = new OpenLayers.StyleMap(new OpenLayers.Style({
> strokeColor: "${getStateColor}"
> }, {context: context}));
> Regards,
> Andreas.
> Pierre GIRAUD wrote:
> > Hello OpenLayers styleMap gurus,
> > I would like to have different symbolizers for the features depending
> > on their state property.
> > The addUniqueValueRules would look perfect for that but the context of
> > the generated rules is feature.attributes. The state will not be
> > evaluated because it's not one of those attributes.
> > Has anyone a workaround to advice ?
> > Regards,
> > Pierre
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
