[OpenLayers-Users] popup hidden when goes on sides of viewport
Kusum
kusum at infobase.in
Wed May 14 06:29:29 EDT 2008
Thanks for thr reply Eric
But still things are a bit messy.
I am using this code:---
markers.events.register('mouseover', markers, function(evt) { feature =
new OpenLayers.Feature(layer,new OpenLayers.LonLat(maplon,maplat));
var maplon_new=maplon+0.005;
var maplat_new=maplat+0.06;
var coord = new OpenLayers.LonLat(maplon_new,maplat_new);
var si = new OpenLayers.Size(240,410);
var link ="<a href='javascript:returnimages();getpics();' >Refresh
Images</a>";
var temp ="<div class='tooltip' id='data'>Name:-"+name+"<BR><BR><FONT
type=verdana size=1>
Desc:-"+p+"</font><br><br>"+imagestr_final+"<br>"+link+"<br></div>";
// popup = new OpenLayers.Popup("pof",coord,si,temp,true
,{autoSize:true},{panMapIfOutOfView:true});
popup = new
OpenLayers.Popup.FramedCloud("chicken",coord,si,temp,null, true,
onPopupClose);
popup.setBackgroundColor("transparent");
var maplon_test=maplon+0.04;
map.setCenter(new OpenLayers.LonLat(maplon_test,maplat),8);
map.addPopup(popup);
function onPopupClose(evt) {
markers.map.removePopup(popup);
popup.destroy();
popup = null;
and its giving this error
OpenLayers.Popup.FramedCloud is not a constructor.
I am confused wat the problem is
Pls suggest..
Regards
Kusum
Sent: Wednesday, May 14, 2008 2:05 PM
To: "Kusum" <kusum at infobase.in>
Cc: "Openlayers Users" <users at openlayers.org>
Subject: Re: [OpenLayers-Users] popup hidden when goes on sides of viewport
> On Wed, May 14, 2008 at 7:28 AM, Kusum <kusum at infobase.in> wrote:
>> Dear All,
>> I am trying to make some nice looking popups and want that the map should
>> pan itself when popup goes to the corner
>> so that the popup comes in the center and is not hidden on any corners.
>> I am trying to use panMapIfOutOfView but its not working
>> Please suggest.
>> Also Can u please suggest me where can I find some examples of good
>> popups??
> You may like the FramedCloud popups that are in 2.6. Check this
> example <http://www.openlayers.org/dev/examples/sundials.html>
> Cheers,
> Eric
