[OpenLayers-Users] Large PNG image degraded when inserted into
smaller DIV
Jeremy Short
jshort at lodgingcompany.com
Thu May 15 14:48:21 EDT 2008
I have a 24 bit PNG image 3872 by 2904 pixels (4 by 3 proportion) which
when rendered in a DIV with those dimensions looks decent, but big.
I want to display this image within a smaller div 400 by 300 pixels to
make it manageable in terms of screen size and so I can use the zoom
tool usefully. However when I do this it degrades the image such that
the writing is jagged and not nearly as crisp, especially noticeable
when I zoom in a couple of levels.
Eventually, I'll be retrieving the image from Mapserver via tiling but I
want to make sure I can render the full size image properly before I
proceed.
Is there a way to perform the desired resizing without the degradation
of quality? Here is the code used.
<style>
#map3 {
width: 400;
height: 300;
border: 1px solid gray;
</style>
<script type="text/javascript">
map3 = new OpenLayers.Map('map3');
var options3 = {numZoomLevels: 4};
var graphic3 = new OpenLayers.Layer.Image(
'Big White',
'/img/BigWhite_300.png',
new OpenLayers.Bounds(-200, -150, 200, 150),
new OpenLayers.Size(400,300),
// new OpenLayers.Size(3872,2904),
options3);
map3.addLayers([graphic3]);
map3.zoomToMaxExtent();
</script>
Jeremy Short
IT Programmer
The Lodging Company
http://www.skihills.com/
