[OpenLayers-Users] changes in wms between 2.4 and 2.6
Joanne Cook
j.cook at oxfordarch.co.uk
Mon May 19 12:45:22 EDT 2008
Hi Chris,
Sorry for the delay in responding to this- but it didn't make any difference:
http://mapdata.thehumanjourney.net/index_26.html
now includes the reproject option.
So, to make sure I understand- do I now need to use the spherical mercator option when overlaying on virtual earth, google et al even if all my data is served in EPSG 4326?
Thanks
Jo
Joanne Cook
Information Systems Coordinator
Oxford Archaeology (North)
01524 880212
http://thehumanjourney.net
----- Original Message -----
From: "Christopher Schmidt" <crschmidt at metacarta.com>
To: "Joanne Cook" <j.cook at oxfordarch.co.uk>
Cc: users at openlayers.org
Sent: 22 April 2008 17:23:29 o'clock (GMT) Europe/London
Subject: Re: [OpenLayers-Users] changes in wms between 2.4 and 2.6
On Tue, Apr 22, 2008 at 05:14:20PM +0100, Joanne Cook wrote:
> Hi all,
> I am wondering if there have been any changes in the way wms is handled between openlayers 2.4 and 2.6. I went to upgrade my site from one to the other, and found that my wms layers display in a different location, when all I've changed is the line that says to look in folder Openlayers-2.6 rather than 2.4 for the javascript.(I even downloaded a clean copy of 2.4 to check it wasn't any changes I had made).
> It looks like a projection issue- you can see the difference if you look at the following:
> http://mapdata.thehumanjourney.net uses 2.4
> http://mapdata.thehumanjourney.net/index_26.html uses 2.6
> If you zoom in far enough to engage the wfs, then sites are in the correct location in both versions of the map.
> Can anyone help me with this- or give me an idea how to debug it?
In 2.5, we turned the default 'reproject' option on WMS layers to
'false', because it offers a false sense of success in overlaying raster
layers of different projections which isn't really accurate.
Setting reproject: true should fix this issue for use now, but you
should really at some point look into using SphericalMercator:
http://crschmidt.net/~crschmidt/spherical_mercator.html explains some of
the how.
Regards,
Christopher Schmidt
MetaCarta
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
